Author: Subject: R1 or ZX12R??
doughie
posted on 10/5/06 at 07:15 PM Reply With Quote
R1 or ZX12R??
what a choice...!!
am looking for advcie about what a zx12 install will look like in erlation to parts and cost...??
i beleive a dry sump is needed (£700), what else is required??
an R1 install is relatively simple with little extra cost on top of the engine...
am i right?
ta in advance for your reply
kb58
posted on 10/5/06 at 07:23 PM Reply With Quote
And no dry-sump for the R1.
The price you have for a dry-sump sounds low. For the Hayabusa at least it's about US$2200.
[Edited on 5/10/06 by kb58]
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
erwe
posted on 10/5/06 at 07:35 PM Reply With Quote
I have a ZX12 seven for track only and a Fireblade seven for road use.
R1 is enough for normal road and light track, ZX12 is way too much power in my opinion. And R1 is much cheaper, even in Netherlands. A friend of my bought a R1 for 750 euros complete with wiring loom and exhaust. I know UK is much more expensive but I had to mention it
Winston Todge
posted on 10/5/06 at 07:38 PM Reply With Quote
Most people will say the same probably...
R1 is proven, reliable, one of the cheaper modern bike engines and fairly straightforward to install, with good power.
The ZX12R has a big dollop more power and torque but will cost you between 400 to 600 quid more for the kit and a fair amount more than 700 quid for a good dry sump... Again though a few have used ZX12's without dry sumps and haven't as of yet had probs.
Simply bang for buck, the R1 is the way to go. But the ZX12 will give you a noticeable hike in performance but at a cost...
Chris.
ChrisGamlin
posted on 10/5/06 at 07:51 PM Reply With Quote
Both are cracking engines for the money and once you factor in the 25-30kg weight saving of the R1 over the big bore engines (busa / ZX12), there's not as much performance difference as the 25bhp power gap would initially suggest, and from experience I would say the performance gap between a blade and the R1 is much bigger than R1 to busa/ZX12.
A ZX12 would still be the slightly quicker car (mostly at very high speed), but there's nowhere enough difference in performance to say things like one is "enough" for road use whilst the other is "way too powerful".
cheers
Chris
[Edited on 10/5/06 by ChrisGamlin]
fesycresy
posted on 10/5/06 at 07:56 PM Reply With Quote
Has anyone tried the GSXR 1000 motor ?
Any opinions ?
doughie
posted on 10/5/06 at 08:02 PM Reply With Quote
wow, cheers guys - thats alot of replies
what are your views on longevity between the two??
G.Man
posted on 10/5/06 at 08:39 PM Reply With Quote
The dry sump kit is about £700+vat, but you need all the pipes, cooler, aeroquip fittings and oil tank as well..
All in around £1200
The dry sump kit gives a hike in performance as well as improved lubrication reliability, so its worth it if you are going for the long run...
Longevity wise, they are both good, but the 12r will last longer in terms of excitement imho
Opinions are like backsides..
posted on 10/5/06 at 08:44 PM Reply With Quote
We have had no problems with not dry sumping our ZX12R BUT we haven't done a trackday in the dry yet... and to be honest we're a little anxious about doing one for the obvious reasons.
We have a well proven chopped and baffled sump but still reluctant to trackday.
The R1 is well proven and used on many kits but is still not as bullet-proof as the blade. IMO if I was to do another it would probably be an R1... as already stated the difference isn't that much!
yorkshire-engines
posted on 10/5/06 at 09:19 PM Reply With Quote
SUZUKI WAY TO GO
doughie
posted on 10/5/06 at 09:38 PM Reply With Quote
suzuki?
chris_harris_
posted on 10/5/06 at 11:15 PM Reply With Quote
I haven't fitted a Suzuki GSXR 1000, YET!! but will be soon. Malc at yorkshire engines loves them, MK engineering has just done one and loves it and mac#1 are doing one too! Your spoilt for choice mate, all good engines, depends on how much money you want to spend, don't think you'll be dissappointed with any choice you make. Also ask yourself, how confident and willing you are in "making" things, you'll need all manner of brackets and things as you go along, especially with an engine that not that many people have used. Good luck though!!
Regards Chris
Winston Todge
posted on 11/5/06 at 06:47 AM Reply With Quote
So people are starting to use the GSXR's now, eh?
Has anyone proven that they don't need a dry sump yet? Thrashed around a dry track sans dry sump without any problems?
Chris.
progers
posted on 11/5/06 at 07:34 AM Reply With Quote
Jury is still out on the GSXR as to whether it will be robust in a seven install i.e. engine longitudinal installation.
Its a well proven engine in sidecars but orientation is different.
I'm looking forward to seeing a few (i.e. more than one) have a good spanking around several tracks with sticky tyres to see how they cope. It'll be good if they stand up to it as it will offer more choice and keep R1 prices down :-)
- Paul
smart51
posted on 11/5/06 at 07:41 AM Reply With Quote
ZX12 is more powerfull but hevier. Power to weight is not much better overall but...
An R1 7 starts to slow down at 90 - 100 MPH. It takes as long to get from 0-95 as from 95-110 MPH. A ZX12 has more power but the same aerodynamics. It will keep on going at 90 and will slow down at higher speeds. ZX12 for track use. R1 is fine for road use.
nitram38
posted on 11/5/06 at 08:17 AM Reply With Quote
While you guys are talking about engines, could you answer another question?
If a bec enginge is mounted the same way round as in a bike, does it still suffer oil surge problems?
The only way oil surge could be a problem, as far as I can see, is that a bec does not lean into corners whereas the R1 would.
I want to build a rear engined R1 car. I know that a baffle plate and slightly different pickup can be fitted (which I will opt for).
ChrisGamlin
posted on 11/5/06 at 10:05 PM Reply With Quote
Whichever way round you fit it, you can suffer oil surge in a BEC. As you say the bike leans into the corner so there are no actual sideways forces on the oil, its counter-acted by the bike leaning, but in any decent BEC there's maybe 1G of cornering forces trying to make the oil run up the side of the engine and away from the pickup.
Some engines (the Blackbird is an example, and also likely the GXSR1000 to an extent) seem happier in the transverse orientation than when mounted longitudinally as in a front engine'd BEC, where they suffer far more from surge simply down to their sump design working better in one direction than the other.
