Keith Weiland
| posted on 29/5/07 at 06:08 PM |
Age related plate or new plate for BEC
Just wondering, is it possible to somehow get a new or an age related plate for a BEC other than using all new parts and spending a fortune or
building with all donor parts then converting to Bike engine afterward?
stevec
| posted on 29/5/07 at 06:19 PM |
Age related is possible.
It is all based on points.
A chassis from a major manufacturer will give you the biggest chunk. then if you use the donor's steering, brakes and axles, with the correct
docs, you will be able to get age related.
Steve,
ReMan
| posted on 29/5/07 at 06:39 PM |
And I did too, like so
Keith Weiland
| posted on 29/5/07 at 08:44 PM |
So I can't build my own chassis and be the manufacturer?
ReMan
| posted on 29/5/07 at 08:58 PM |
I believe, technically no.
However I also believe it's possible to get an age related plate even if the chassis is not counted, but plenty of other "major "
parts are.
You'll notioce I used believe twice, here so I don't look any more stupid than usual f someone disaggrees
