Author: Subject: number 1
iceman26
posted on 6/9/07 at 05:38 PM Reply With Quote
number 1
im having a mad 5mins so
is number 1cylinder at the sprocket end
or the timing chain end
thanks
t.j.
posted on 6/9/07 at 06:06 PM Reply With Quote
Normal at the timingbelt/chain
iiyama
posted on 6/9/07 at 06:13 PM Reply With Quote
So no.1 is effectively at the front of the car then?
Is that for all engines? I have a Hayabusa and was pondering exactly this point!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
iceman26
posted on 6/9/07 at 06:19 PM Reply With Quote
im not sure as not all car engines number1 is at the chain/belt end
as renault number 1 is gearbox end
so any one know for sure
thanks
locoR1
posted on 6/9/07 at 06:34 PM Reply With Quote
Not sure about the Hayabusa but on the R1 no1 is at the sprocket end I found out the hard way when I first tried to start mine !
dave............
Check out my CB500T Cafe Racer build diary
iiyama
posted on 6/9/07 at 06:47 PM Reply With Quote
Was sort of hoping that No1 is the sprocket end!
locoR1
posted on 6/9/07 at 06:57 PM Reply With Quote
I assume that you've got it right first time then! Smart arse!
iiyama
posted on 6/9/07 at 08:08 PM Reply With Quote
Dunno bud, havent started it yet! Making up the loom and thats the way the cables sort of fell, which is why I was hoping it was the case that 1 was at the sprocket end!
If it starts, (which will be a miracle due to the amount of loom mods Ive made!!!), Ill let ya know. Then you can call me a smart ass!!!!
jos
posted on 6/9/07 at 09:05 PM Reply With Quote
if your engine management runs a wasted spark system then I thought it doesn't matter which cylinder has which spark plug connected to it as there will always be a spark when the piston is up at the cylinder head
but I stand to be corrected
matt_claydon
posted on 6/9/07 at 11:31 PM Reply With Quote
Correct, for wasted spark on a 4-cylinder it doesn't matter - the engine and it's operation is symmetrical.
