Mezzz
| posted on 10/5/06 at 11:48 PM |
ok so you can use the clutch when going both up and down its really just your choice how you use it.
But the main thing is that you can use it with out the clutch or with the clutch going up the gears.
But when going down the gears eather way you should use the clutch
and of course when taking off from stand still you must use the clutch (duhh so obvious)
And then off topic but as BEC have such close gears whats the top speed for a R1?
wildchild
| posted on 11/5/06 at 07:21 AM |
yep, thats about right.
please use the clutch to change down!
up is optional.
an actual R1 will probably do about 170 , in a car it obv depends what diff you've got.
the gears are close but it's generally through having a long first gear rather than a particularly short top gear.
