zilspeed
| posted on 4/1/09 at 10:10 PM |
Wee bit more progress
Seeing as I'm looking to get this engine fired up soon, went and picked up a fuel pump from Mr. Westgarage yesterday.
Having got that home, I figured that I would want to crank the engine and have oil pressure before givng the engine sparks or fuel.
So, need to fill the engine with new oil, because I know for a fact that the sump is empty. Hang on though, that sump is getting changed for a shorter
GPZ900R sump, so might as well do that first. Did it, also managed to hook up the oil cooler lines too.
That job done, I know that I can now put the oil in, just need an oil light now. That's in the bike clocks, time to break out the wiring diagram
to make sure I have identified the right wire. While I was at it, I figured I might as well go the whole hog and identify all the wires to the bike
clocks so they can be wired in correctly.
Did that too.
So, tomorrow I need to get some engine oil, some fuel hose, some hose clips a handfull of electrical connectors and some heat shrink.
I think I will be good to go at that point.
Once it fires, it will be time for the gearchange mechanism. Mr McGill's rod end emporium will be the place for the necessary joints.
A good day, all in.
RichardK
| posted on 4/1/09 at 10:13 PM |
don't forget the start up vid m8
Rich
Gallery updated 11/01/2011
minitici
| posted on 4/1/09 at 10:31 PM |
Hi John,
I chopped a spare zx10 sump and welded it up this afternoon.
Just need to weld a bush on the side for the oil drain plug.
Certainly don't want the bottom of the sump to get wiped off (like Stuart Brown's OMS ZZR1100 at East Fortune).
[Edited on 4/1/09 by minitici]
zilspeed
| posted on 4/1/09 at 10:48 PM |
quote: Originally posted by minitici
Hi John,
I figured that swapping for a GPZ900 one was way easier for me.
  Difference in depth
I really hope you are able to get the time to get the work done on the Royale, because much as it's always great to have you marshalling, it has
to be better to be driving.
andyw7de
| posted on 4/1/09 at 11:27 PM |
Im impressed John
Is the push on for the start of the season
Hows the "nudge nudge " bit coming on
keep up the good work
zilspeed
| posted on 4/1/09 at 11:33 PM |
quote: Originally posted by andyw7de
Im impressed John
Andy, that's pretty much it.
I'm getting as much done now while the mood is on me.
Once the engine runs, it will be drivetrain time at which point it all becomes quite interesting potentially.
How's the beemer coming along.
dave1888
| posted on 4/1/09 at 11:44 PM |
Would you like a video crew to film the experience. I have a full battery and an empty 8gig card choking for some hot action.
andyw7de
| posted on 5/1/09 at 01:06 AM |
Its all ground to a bit of a halt at the moment need to get my arrr- backend into gear.
need the ignition rewired, harnesses fitted and paint to finish before final set up,
Im crap with wires and fed up of rubbing down. need a good kick to get me going.
If its ready for the start of the season ive promised Douglas a drive as i cant compete with my lowly grade 'B' license, thats assuming it
will get round the bottom corner onto the start line
All the best
zilspeed
| posted on 5/1/09 at 05:07 PM |
Why can't you compete with your grade B licence ?
Is it a car, driver or event issue ?
zilspeed
| posted on 5/1/09 at 05:08 PM |
Sounds like a plan.
Will continue with my preparations and contact you as the time draws near.....
andyw7de
| posted on 5/1/09 at 05:16 PM |
Its a car issue
Due to it being modified to the extent that it is , it will be under sports libre and as such with a grade B you can only drive up to a 2000cc car
mine 2500cc and may even be 3000 or 3200 if i can get enough £££
heho should have checked before i modded it
zilspeed
| posted on 5/1/09 at 05:27 PM |
Its a car issue
So you're in Sports Libre, but a 500bhp Mitsubishi is a road car ?
That's a joke.
What you need is some events in a road car to get some signatures on your licence.
P.S. Looking for a nice waterjet gearchange paddle. How much ?
[Edited on 5/1/09 by zilspeed]
andyw7de
| posted on 5/1/09 at 06:48 PM |
That's a joke.
Aye does seem a bit strange but thems the rules.
If Id left the sloppy steering, spongy suspension and crap brakes on the original body then Id be ok in road going or even modified road and would
probably have seen even more of the gravel traps than i did with the FVL which had a much higher power to weight ratio
Im looking at some cheap kit options to get some signitures or the wifes old Puma still shut up in the garage
Bet she will be pleased
Anyway if the Beemers ready for Douglas it will be nice to see it driven properly before i take it off road
