matt.c
posted on 30/1/09 at 11:32 PM |
Paddleshift cable Vs Rods?
Ok now i have got a nice shiney set of paddles. Now next question is should i go cables or rods?
Please give a good reasion for your choice and how much either costs?
Also where did you get them from?
Pdlewis
| posted on 30/1/09 at 11:41 PM |
Id go cable as it cheap easy to route and you dont need any pivots. Cable £10 outboard motor cable off ebay push/pull couple of rose joints jobs a
udun .
Cable can also give a better shift if you mount the backet on the engine so it move with the engine also a bit gentler on the change
Build Photo Album
Updated 05/02/2009
YQUSTA
| posted on 31/1/09 at 12:00 AM |
I went for cable as above for easy routing.
got mine from here.
They also sell the securing clasp type thing too.
If I recall correctly the ends are m5 and its cheaper to buy rodend's/clevis from the bay than from them.
I also went for the supreme cable as it was better for the tighter bends and for the little extra I thought it would be worth it.
YQUSTA
Steve Hignett
| posted on 31/1/09 at 12:27 AM |
Rods, youtwoyou sent
locoR1
| posted on 31/1/09 at 08:47 AM |
Would have to say cable easier to fit and less complicated that rods and pivots.
I had my cable made to order to the length + with the joints i wanted from midwest controls in the usa and it only cost just over £30 delivered they
even sent it as a commercial sample so no import tax!
Check out my CB500T Cafe Racer build diary
adithorp
| posted on 31/1/09 at 02:37 PM |
I went for rods on mine. Mainly because there was a convenient place to mount a pivot (only needed one) and the rod lines were nice and easy to
accomodate. I had a cable but mounting the ends was more difficult.
Whichever you go for, make sure the pivot or cable outer anchor points are firm enough not to flex. A small amount of flex makes a huge difference to
the feel.
adrian
http://jpsc.org.uk/forum/
Meeerrrk
| posted on 31/1/09 at 03:59 PM |
mine is a cable, seems to work fine; ive had no problems with it (yet!)
mArk
For Sale : 2008 Aries/Stuart Taylor Motorsport Locoblade (954 Blade)
mads
| posted on 31/1/09 at 05:39 PM |
Out of curiosity, any particular you not chosen electric as an option Matt? I'm not that far into my build to even start researching the
pro's and con's of each but just wondered why noone has mentioned it...
edit: and if you cant get electric paddleshift then just ignore me... had a long day tidying the garage
[Edited on 31/1/09 by mads]
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
Meeerrrk
| posted on 31/1/09 at 07:09 PM |
cost, or at least it would be in my case; calbe works fine, why spend that much on an automated system?
roadrunner
| posted on 31/1/09 at 08:01 PM |
Have any of you cable guys got picis of your anchorage points please.
Where did you get your paddles from Matt, got any picis.
Brad
matt.c
| posted on 31/1/09 at 08:22 PM |
Havent got electric because i cant afford it.
[Edited on 31/1/09 by matt.c]
locoR1
| posted on 31/1/09 at 08:58 PM |
Brad
Brad i have only got pics of the dash end if you want some of the engine bay i can take some tomorrow to cold out there now
Cable isnt fitted but you should get the idea.
engine bay end will depend on your engine the r1 gear change is high up so my cable is bracketed of the diagonal rail in the engine bay.
[img][/img]
SPYDER
| posted on 1/2/09 at 07:11 PM |
Brad
Hi Brad. Here is the fabricated upper cable bracket on our Phoenix. It is VERY stiff and securely bolted to the cross tube of the cage. The bolts
come upwards through tubes welded into the cage tube. As already stated, stiffness is paramount.
The paddles are Titanium.
Geoff.
[img] [/img]
roadrunner
| posted on 1/2/09 at 08:17 PM |
Thanks guys, i hope i can get somewhere close to that sort of quality workmanship.
