Jason Fletcher
| posted on 8/2/09 at 11:12 PM |
Blade with carbs, how difficult would SVA be?
Hi Guys
I'm thinking of buying a car that has spent it's life on the track and has never been registered so I will need to SVA it (if I'm
quick) The car has a Blade on carbs in it and I am wondering if it's likely to be a P.I.T.A to get the emmisions right?
thanks
Jason
| posted on 8/2/09 at 11:16 PM |
What year is the engine? Carbed Blades can either be pre or post 1995. Obviously pre 1st August 1995 gets the easy emissions test at SVA but even if
it's post 1995, it shouldn't be a problem to get through.
Phil
Jason Fletcher
| posted on 8/2/09 at 11:19 PM |
Hi Phil
the car is a 2002 so i guess the engine is 2000/2001.
As the car is going on a Q anyway can't I tell them it's a pre 95 and get the easy test?
Jason
[Edited on 8/2/09 by Jason Fletcher]
cloudy
| posted on 8/2/09 at 11:28 PM |
Depends on the year of engine - if its pre 95 its a doddle, else you'll need a CAT at least
Jason Fletcher
| posted on 8/2/09 at 11:34 PM |
How will they know what year the engine actually is?
Steve Hignett
| posted on 8/2/09 at 11:36 PM |
If the engine is 2001/02 then it won't be a Blade on Carbs.
You will need to find out what year the ACTUAL ENGINE IS and then you will know how simple the SVA will be. Although TBH a Carbed Blade engine is
simple either way...
What's wrong with the Caterham Busa you're building?
quote: Originally posted by Jason Fletcher
Hi Phil
Jason
| posted on 8/2/09 at 11:37 PM |
Find the engine number and then look up the engine year in the Fireblade manual. If it's on carbs then its certainly pre 1999. I think the RRX
was the last of the carbed blades.
Phil
[Edited on 8-2-09 by Hellfire]
Steve Hignett
| posted on 8/2/09 at 11:39 PM |
  Blade Engine numbers
| posted on 8/2/09 at 11:42 PM |
Alternatively look for the CC capacity which is embossed on the engine block. If it says 893, you have a chance of the easier emissions at SVA. If the
number is 918 or higher, you'll get the stricter emissions test.
Phil
Jason Fletcher
| posted on 8/2/09 at 11:43 PM |
Right, I'll find the engine number out.
The Caterham Busa is done now and I'm looking to get a track hack at the right money. Mainly because I have never done a track day and I
don't want to make a kill the Caterham just yet.
Jason
Steve Hignett
| posted on 8/2/09 at 11:47 PM |
Why are you SVAing it if you just want it for trackdays?
What's wrong with taking a caterham on the track - I know which I'd rather be on track with!!!
Jason
Jason Fletcher
| posted on 8/2/09 at 11:54 PM |
Hi Steve
thanks for posting the engine numbers.
I did want it for track days but I will also want to road test it once ive done mods ect. This track hack is also a Caterham but just a bit bashed up
so when I stuff it into the armco I won't get too upset.
Jason
Steve Hignett
If you don't want to risk the caterham then I would suggest you have a very close look at the first car in this post...
http://www.locostbuilders.co.uk/viewthread.php?tid=105960
Jason Fletcher
| posted on 9/2/09 at 12:07 AM |
yes a really nice car at a real bargain price. But unfortunatly not an option for me because I would want to SVA it and that would not be as easy
forme to do before end of this month.
Jason
Jason Fletcher
| posted on 9/2/09 at 11:11 AM |
it turns out the engine is a 1998.
| posted on 9/2/09 at 05:03 PM |
They just test it as a new unit unless you have proof of it's actual age.
Jason Fletcher
| posted on 9/2/09 at 08:40 PM |
thanks Pete.
