Author: Subject: R1 5vy wiring Cyclelock non starter help
Davg
posted on 9/1/10 at 03:00 PM Reply With Quote
Stripping loom & all usual suspects dealt with ie sidestand, clutch, tilt sensor & cutt-off and junked lights circuits. Still having issues with the cyclelock wires that were previously chopped. Engine cranks over although not sending signal to ECU to start /prime pump still having problems finding where to connect the 2 wires previously associated to the cyclock methinks, 1 comming from the ingition switch and the other from red/green backup fuse. Any thoughts? Some pics in piccys of the offending in archive 'loom' cheers D
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 9/1/10 at 03:46 PM Reply With Quote
May help your cause i don't know.
http://www.scribd.com/doc/2634179/yzf-r1-manual
Davg
posted on 9/1/10 at 04:03 PM Reply With Quote
Cheers for that Craig. already got diagrams, problem is thet don't show the ignit immob circuit.
thanks again though. D
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 9/1/10 at 04:18 PM Reply With Quote
Think its U.S spec that doesn't have the cyclelock so thought between this and the uk diagram you may be able to work it out.
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 9/1/10 at 04:20 PM Reply With Quote
What about this.
http://www.robcollingridge.com/kitcar/build/2006/04/index.html
fesycresy
posted on 9/1/10 at 05:23 PM Reply With Quote
Taken from speed8 many years ago:
Cycle Lock 03 R1
Cycle Lock 03 R1
And it works.
Davg
posted on 15/1/10 at 04:02 PM Reply With Quote
AArgh!
thanks guys
appears the 5vy is a bit different.
To confirm set up includes uk loom which incorporated the immobilser key. i have the key & matched ecu & alos ow got another un-chopped loom.
can anyone confirm the connection that need looped from the 2 plugs in the pics hopefully posted.
white 2 pin plug
1 - immob transponder at key
2 - red/brown to backup fuse.
other 4 pin plug
2 - go to indicators so no connection req'd
1 - earth
1 - Brown signal/turn fuse feed
as said set up slightly differs from from older R1s
thanks D
Image deleted by owner
[Edited on 15/1/10 by Davg]
Davg
posted on 15/1/10 at 07:27 PM Reply With Quote
with pics added at last!
[img][/img]
