fullpint
| posted on 5/2/12 at 05:37 PM |
Any CBR919 near SN13 area?
I'm after a peek at your chole set-up. I had a member give me a choke cable and I also purchased a mini type cable so that one day I can run it
thru into the dash.
However my problem is; When I pull the choke cable every thing works fine and the engine starts on the button first time. The ONLY way to turn the
choke off is to manual push the choke rod plate back towards the bulkhead. Question is should there be some sort of return spring to aid the return of
the choke rod plate
I've over 28 years in dealing with magnesium wheels. Refurbishment and can powder coat most metal parts. Visit my web site if you wish..
www.tpcs-magnesium-refurbs.co.uk
Dangle_kt
| posted on 5/2/12 at 06:04 PM |
I don't have my car anymore, but the choke plate was spring loaded on mine, had to keep it pushed on with my finger or it the choke would switch
off.
I always intended fittin the choke cable I had, but never got round to it.
mark chandler
| posted on 5/2/12 at 06:19 PM |
On the choke bracket on the carbs they should be a spring like you find in a click top pen, this sits at the end of the mechanism on a couple of
lugs.
Regards Mark
fullpint
| posted on 5/2/12 at 06:31 PM |
Hi Mark; That sounds like what I should have!!
Just took a pic, if you have a look I presume the pen like springs (4 off??) fit into the gap. 3 being the same size and one needed to be a bit
longer!!
mark chandler
| posted on 5/2/12 at 07:05 PM |
That's it, spring goes under the slide on that lug
fullpint
| posted on 5/2/12 at 07:16 PM |
Will drop an email to David Silver to see if they have a set in stock.. Cheers;
tony.g
| posted on 5/2/12 at 07:19 PM |
Check this diagram out I think it's no 10
I will try and take a photo of mine later.
http://www.hondaoriginalparts.com/honda_motorcycle_parts_selection_pfk.php?block_01=13MW0N41&block_02=E__1800&block_03=1158
fullpint
| posted on 5/2/12 at 07:31 PM |
That would be good mate. So it's only 2 springs that are needed?
Proby
| posted on 5/2/12 at 08:59 PM |
Off the top of my head, I think there is only one spring, at the one end. Will take a pic and post it tomorrow if needed.
tony.g
| posted on 5/2/12 at 10:01 PM |
There is only a spring on my rear carb, and there is a photo in my photo archive.
I don't know how to put it on this page.
I hope this helps.
Tony
Chippy
| posted on 5/2/12 at 11:02 PM |
This one? Cheers Ray
[img]
  choke spring
[/img]
fullpint
| posted on 6/2/12 at 06:14 AM |
Cheers all, makes me wonder why mine was taken off!! Or may be the previous owner(s) didnt feel the need to carry the extra weight
brookie
| posted on 6/2/12 at 04:31 PM |
i got the 919 and dont have one fitted at all
fullpint
| posted on 6/2/12 at 05:14 PM |
How do you get on with a cold start?
Ok David Silver have come back but it's not clear how many compression springs are needed. That diagram shows item number 10 (2 off) and also
number 9.. Also want £4 each for a sprng
brookie
| posted on 7/2/12 at 04:18 PM |
i dont in the winter but spring and summer fine
