jossey
| posted on 9/7/13 at 09:08 PM |
Fireblade 893 cooling setup.
So I'm a little stuck with setting the coolant pipes on the 893 I'm installing....
I've looked at a few pics but seem none the wiser.
Has anyone got a diagram showing the coolant pipe setup please
[Edited on 9/7/13 by jossey]
David Johnson
ReMan
| posted on 9/7/13 at 09:33 PM |
Like so?
Worked for me.
Just get the header tank cap as high as poss
[Edited on 9/7/13 by ReMan]
www.plusnine.co.uk
Doctor Derek Doctors
| posted on 10/7/13 at 07:34 AM |
I simplified mine slightly by doing this:
When you fill the system just open the bleeds and then fill the header tank until water is coming out of both then lock them off. I had no air traps
and have had no cooling issues. For Bleeds I just used ~30mm of pipe with a small bung in the end which I looses off.
Also make sure you have no air traps in the line (I.E raise areas of pipework) were are pockets will get stuck.
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
jossey
| posted on 10/7/13 at 12:47 PM |
Thanks so much makes a lot more sense
David Johnson
jossey
| posted on 24/9/13 at 08:18 PM |
Thanks again for all the help here Guys. My rad doesnt have the bleed nipple thing as im using the Polo rad.
What does that mean for me please?
David Johnson
ReMan
| posted on 24/9/13 at 08:23 PM |
Nothing, I've got no bleeds, I thought that that was the point of the header being the highest point?
Never needed to bleed i dont think!
www.plusnine.co.uk
