sdenne
| posted on 16/9/20 at 07:53 PM |
Quaife reverse box play
Hello,
I have recently purchased a used Sylva Phoenix R1 with Quaife reverse box.
There is a play of about 8 mm between front and rear flange when forward gear is engaged.
Is this okay or how can I adjust it.
Regards
Stefan
minitici
| posted on 17/9/20 at 08:16 AM |
That will be the normal play between the gear engagement dogs.
watsonpj
| posted on 17/9/20 at 08:39 PM |
Yep my quafe has a lot of rattle,it's fitted as standard on all their boxes. Rotational play is normal the thing to check is play side to side
on the input/output. I had a bearing go.very early on which they replaced.
