mad-butcher
| posted on 2/6/05 at 09:56 AM |
blade starter relay wiring
thanks for the help and patience so far
just need to wire starter relay up.so far i've got and works... green/black to earth... white to starter button...to the 2 remaining spade
terminals which one does the rectifier output go to and do i have to use the other one as i already have a feed off the battery to the ignition
switch
many thanks
tony
ReMan
| posted on 3/6/05 at 08:39 AM |
technically its the botton left in the picture that goes to the rectifier output, right to the ignition, but I am fairly sure they are both joined
internally anyway.
www.plusnine.co.uk
