smart51
| posted on 16/8/05 at 09:07 PM |
98 R1 clocks
Which wire on the 98 R1 clock is for the back light? According to haynes it is "blue" (bottom left hand corner) but this doesn't
work. It's the only thing left to do on my dash now. I'd hoped to finish before it went dark.
| posted on 17/8/05 at 12:39 AM |
Don't know specifics about R1 clocks but most have a common earth. Is this connected...?
smart51
| posted on 17/8/05 at 02:05 PM |
The earth is connected yes. The bike loom and car loom are both connected to the battery so share a common earth.
The main beam warning lamp is connected to the car loom, as well as the indicator warning lamp and the back light. The main beam lamp works OK. I
guess that I've got the wrong wire for the back light.
Coose
| posted on 17/8/05 at 03:14 PM |
Hmmm.... I'll try to have a look in the Yamaha manual tonight. You say it's a '98?
Spin 'er off Well...
smart51
| posted on 18/8/05 at 12:11 PM |
yes, it's a 98.
Coose
| posted on 18/8/05 at 12:46 PM |
Sorry, never got the chance to look last night. I'll try again tonight though....
Winston Todge
| posted on 18/8/05 at 01:16 PM |
Have you checked in Yamaha's service manual? Might be in there...
http://dsr.racer.net/ under 'engines' -> R1
Chris
[Edited on 18-8-05 by Winston Todge]
Coose
| posted on 18/8/05 at 08:17 PM |
Yes, the feed is on the blue wire at the clocks. I take it that you don't have 12v present there? You should be switching the blue from a
brown/red. Is the fuse supplying the brown/red ok?
This is why I used the R1 loom complete and extended and added to it where required....
