Author: Subject: Carb Heating System
birt
posted on 31/8/05 at 07:58 PM Reply With Quote
Carb Heating System
Appologies to those that heve seen this on the Yahoo BEC lsit but...
Are you ZX9R people running the carburetor heating system or have you removed it and plugged up the holes in the head and water pump...?
I would like to remove it but don't want to experience problems.
Mad Dave
posted on 1/9/05 at 05:57 AM Reply With Quote
I left it in because I thought what's the benefit of removing it?
Wadders
posted on 1/9/05 at 05:20 PM Reply With Quote
You dont need it, bin it.
birt
posted on 1/9/05 at 06:29 PM Reply With Quote
2 sides of the argument here!
Dave:
I guese the only reason for removing it is to tidy up the bunch of pipes that are required for this system... So probably not really much of a reason. I suppose I was hoping I would get loads of people all agreeing that it isn't needed so I just could remove it and forget about it.
Wadders:
I believe that the temp doesn't need to be that cold (certainly doesn't have to be freezing) for the carb jets to ice (due to air cooling when passing through venturi). Have you never had any fueling problems?
Interestingly, looking at your pictures, you seem to be running with the emmisions reduction system from the bike.... I thought this was the first thing to bin?? Do you think it is necessary?
Marc
Wadders
posted on 1/9/05 at 07:26 PM Reply With Quote
No probs whatsoever, and yes bin the emmisions thingy too, it's not necessary.
Originally posted by birt
Wadders:
Marc
Mad Dave
posted on 1/9/05 at 07:59 PM Reply With Quote
Bike mechanic mate of mine said you might as well keep the carb heaters on and now they are on and the car is working I can't be arsed to bin it. I don't think I will be driving when its cold enough to freeze the carbs though.
I binned the emmisions thingy due to the crap noise it made through the air filter. Sounds much better now!
