billy
| posted on 1/10/05 at 07:53 PM |
Can i Join in???
Hi lads, i just picked up my zx12 engine and gonna be picking all your brains, with annoying questions your gonna make me pay for all the XE
ribbing ive been up to on here now, he he, whats all the black boxes about????
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
smart51
| posted on 1/10/05 at 08:45 PM |
I guess.
| posted on 1/10/05 at 10:24 PM |
Flight recorders?
Rorty
| posted on 2/10/05 at 06:09 AM |
quote: Originally posted by billy
...whats all the black boxes about????
Don't know, caucasian women don't have them.
They're the bike world's version of a car's on-board computer. There's usually not a problem as long as you have the one that
was originally fitted along with your engine.
Problems arise when people are sold one from another year/model etc. or they've mis-wired the car.
Cheers, Rorty.
| posted on 2/10/05 at 09:15 AM |
Most black boxes are relays...
Then ECU, Regulator/Rectifier, lot's of sensor's regarding temperature and air pressures.
Make sure you have the ignition barrel as this contains a small resistor which is vital if you want to start the thing
It looks like a total glut of wiring... most you can chop out as it is made to suit the bike. Just be careful and follow a path - get a good
electrical diagram and follow it circuit by circuit. It all comes together pretty easily. Trust me, I'm no electrician but I did it without so
much as a fuse blown or error - flat battery allowed?
Great engine - apparently better than a Hayabusa due to output gearing... but who knows? I don't think there's much to seperate any of
them really...
HTH - feel free to message or U2U if you need specific questions.
billy
| posted on 2/10/05 at 07:52 PM |
Noooooooooo, ive no ignition with it  i seem to have everything else and was pretty chuffed. thanks for offering the help as i know im gonna need
alot what keeps me going now is hearing yours singing on your video great stuff
| posted on 2/10/05 at 08:43 PM |
Did you get the ram pipes (air trumpets), fuel pump and sender?
Just a few of the things that are so easily overlooked - not necessarily vital though.
billy
| posted on 2/10/05 at 09:28 PM |
look
mmmmmmmmm
billy
| posted on 2/10/05 at 09:38 PM |
XE in background
LoL look at the poor old xe lump in the background he he he he
Can't see any of the parts mentioned above. Is that it, or is there a box full of other bits such as ecu, rec/rec and sensors etc?
billy
| posted on 2/10/05 at 09:42 PM |
I have all the loom and boxes, ill take a pic tommorow and feel free to tell me if theres any bits missing, i need to find out the age and model it
is, this is 1 big engine aint it
billy
| posted on 2/10/05 at 09:44 PM |
pic
heres another pic of a trial fit in me car
| posted on 2/10/05 at 09:59 PM |
Looking at that pic you have two of the ram pipes in position, so theres probably another two in the box you mentioned.
Any chance of a picture showing the other side of the engine. This may help to identify what year it is.
tadltd
| posted on 3/10/05 at 11:14 AM |
Don't worry if you don't have the ignition barrel/switch. You just need to splice a 100 ohm resistor into the grey wire from the ignition.
Best Regards,
Steve.
www.turnerautosport.com
billy
| posted on 3/10/05 at 02:37 PM |
Great, thanks for that. heres a pic of the other side
tadltd
| posted on 3/10/05 at 08:06 PM |
It's definitely an A1 or A2. The 'B' engines have a fancy throttle control between no. 2 & 3 throttle bodies.
Best Regards,
Steve.
| posted on 3/10/05 at 08:16 PM |
Ours is a 2004 engine and has a similar throttle arrangement (as picture), although the engine mounting bracket on the exhaust side, looks to be
different
[img][/img]
