badding
| posted on 9/10/05 at 08:36 PM |
zx9r wire loom '98
Does anyone has an haynes manuell about the wire loom, I can't seem to figger out where all the connectors are going too...
And also I have bought a '98 zx9r speedo and my question is, is it possible too use this speedo in regards to the speedsensor that gets
it's readings form the front sprocket.
| posted on 9/10/05 at 09:19 PM |
ive got the full diagram laminated in a3, for all years of zx9. Got any specifics question?! no idea about the speedo though.
Mad Dave
| posted on 10/10/05 at 06:03 AM |
There is a wiring diagram for an 'E' model ZX9R in my pic archive. It is similar to the 'C' model so it might help. If I
remember I will scan the 'C' diagram later this week.
Dave
badding
| posted on 10/10/05 at 05:05 PM |
If you could post it, you would make me verry  Dave.
[Edited on 10/10/05 by badding]
| posted on 10/10/05 at 06:41 PM |
sorry, thats massive... any smaller and its not readable though.
moved to my archive
[Edited on 10/10/05 by JoelP]
badding
| posted on 11/10/05 at 07:59 PM |
Is the zx9r E model engine the same as the zx9r C in regards to the wiring.??
| posted on 11/10/05 at 08:09 PM |
it would appear to be broadly similar in the wiring layout, but i couldnt comment on things like connector compatability.
Mad Dave
| posted on 12/10/05 at 06:02 AM |
Oops I've just remembered I was supposed to scan the wiring diagram.
When I got my engine I was told that it had everything to get the engine running except the ECU. I later found out that with my 'E'
engine I had all the 'C' running gear! The wiring is similar and from what I remember the connectors are the same but the 'C'
has a cam shaft sensor and only one headlight relay. I made a seperate loom for the engine and one for the lighting then spliced them together. With
the 'E' wiring diagram you could make a start.
Dave
tks
| posted on 12/10/05 at 09:00 PM |
doens't the later spec E
had also an cam pos sensor?
are both injection?
Tks
