Author: Subject: Blade (Head Off)
ASH3
posted on 31/10/05 at 05:52 PM Reply With Quote
Blade (Head Off)
I have one if not two inlet valves in trouble in No 4;
Can you tell me the do s n donts involved.
Should i take the head to be done for me or
is it a job i can tackle?
Plus the best place for parts.
andrew.carwithen
posted on 31/10/05 at 06:36 PM Reply With Quote
Ash, there's a couple of cylinder heads on ebay at the mo' and cheap too!
Item no.s 8010118674 and 8011350616
(Someone more clever than I will be able to do a link, no doubt.)
Alternatively, it might be worth giving Andy Bates a call at AB Performance for advice as he is an expert on the 'blade engine. Tel 01284 703101.
Provided you've got a Haynes manual and a 'motorcycle' type torque wrench, (one with a low torque setting range) then I would've thought you should be able to do the job yourself.
Andy.
ChrisGamlin
posted on 31/10/05 at 07:10 PM Reply With Quote
I flogged my blade heads for around £50 each so it would probably be more more economical to buy a second hand one like those Andrew has highlighted assuming they are good!
You'd still want a Haynes manual to guide you so you get all the cam timing etc right when refitting, but should be a DIY job.
ASH3
posted on 6/11/05 at 06:37 PM Reply With Quote
Its not a job to be frightened of i have enjoyed every bit of it so far just got to put it back together..
ASH3
posted on 15/11/05 at 10:09 PM Reply With Quote
All back together but got a problem..
Number 4 on reving blows fuel back n soaks the air filter. She does not rev freely under 4000rpm over that its fine. I put std can back on thinkin it dont like the race one but to no avail any clues!
ASH3
posted on 19/11/05 at 07:53 PM Reply With Quote
Think ive got it had the carbs
off n found two things all my trouble
has been in No.4 pot. With the carbs
off lookin at the inlet valves 1,2 n 3 are wet
with fuel 4 dry as a bone... found the accelerator pump diaphram was hagin out its
hsg + only found the choke slide is bent n has been holdin No.4 choke partly on
ASH3
posted on 23/12/05 at 06:06 PM Reply With Quote
At long last got my bike chap
to bring along the tappet shim
box 4 hrs later sorted!Dont think
she has ever ran on all four properly
thought the thing was fast before but now
. Grindin shims down is no fun always
the size your after the box is empty of.
Well happy for Xmas now
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 23/12/05 at 09:47 PM Reply With Quote
Well done you got there in the end!
posted on 26/12/05 at 11:41 PM Reply With Quote
Looks like fun
