Paul G
| posted on 21/11/05 at 03:19 PM |
R1 Clutch problem
Well I was just about to take my first test drive in my MK Indy (just down my drive cos I'm waiting for a brake caliper), engine in neutral and
started, handbrake on, clutch fully down - I change to first gear and the car lurches forward and stalls - this is while the clutch is still down. I
jacked up the rear end and started it in first with the handbrake off and the rear wheels spin wether the clutch is fully in or out it has no effect
at all. operating the clutch by hand and it seems to have full travel, the clutch arm moves by 90 degrees. Is the clutch shafted or am I missing
something here??
Paul
ps its a 98 r1
Oliver Jetson
| posted on 21/11/05 at 03:40 PM |
Paul,
When you say you are operating it by hand do you mean you are moving the actual clutch arm by hand?
If this is the case you are probably only taking up the slack in the clutch arm return spring. The clutch is activated after this intial spring take
up, and is very hard to do by hand. should move another 10/15mm after the spring.
Oli
Paul G
| posted on 21/11/05 at 03:46 PM |
Hi Oliver
Well I've tried it using the clutch pedal but perhaps I havent set the cable tight enough then, are they really that hard to move?? I'll
go have a look now
Paul
ChrisGamlin
| posted on 21/11/05 at 03:48 PM |
Agreed, you would really struggle to fully depress the clutch by hand just by pulling on the actuator arm, the first 90 degrees is just taking up the
slack on the return spring.
Chris
jimgiblett
| posted on 21/11/05 at 03:53 PM |
As Oli says or if not this it might be that your plates might need freeing off.
Have you had the clutch apart? Sepatating the plates for a quick inspection of the plates often frees the clutch up if it has been standing around
for a while.
Paul G
| posted on 21/11/05 at 04:34 PM |
IT WORKS!!!! I'm well chuffed after 4 months of hard work I've actually built a car!!!! It was just taking up the slack at first, I
hadnt realised that the actual clutch operates further after that.
Just waiting on MK to send me the bottom slider bit of a front brake caliper and then I can go for a proper test drive!
Thanks all for the advice I'm off for a beer or ten to celebrate!
Oliver Jetson
| posted on 21/11/05 at 04:43 PM |
Awesome, glad we could help
Oli
RichieC
| posted on 21/11/05 at 05:23 PM |
Well done mate, 4 months? From start to finish?
Really good going if so
Regards
Rich
Paul G
| posted on 22/11/05 at 09:24 AM |
Well its probably more like 5 months but I went on holiday for 3 weeks in that time and now I've got to get all the legal sva stuff ready.
Problem is I've only got a carport to work under and its getting bloody dark quick and a bit cold!
RichieC
| posted on 22/11/05 at 07:16 PM |
Good skills,
Ill be absolutely over the moon if i get mine built in even 6 months.
Rgds
Rich
