Author: Subject: spring rates
mark.s
posted on 3/12/05 at 09:40 AM Reply With Quote
spring rates
Hi all
Is there a preferd spring rate for bec, im getting an Avon kit in Jan and want to start getting a few bit together
Mark
Avoneer
posted on 3/12/05 at 01:10 PM Reply With Quote
Don't buy your shockers from Tiger - they're still selling the wrong length for the front.
Do a search on springs - this has been covered a million times, but there's seems to be no clear answer.
Pat...
kb58
posted on 3/12/05 at 04:24 PM Reply With Quote
Correct, there is not One Answer because it depends greatly upon the installed ratio. That said, if you find someone else with your *exact* same chassis, you can safely use their spring rate and at least be close. Of course spring rate is a personal thing too... what one person thinks is perfect another will consider way too stiff...
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
mark.s
posted on 3/12/05 at 08:08 PM Reply With Quote
Pat...
Pat what are the right shock lengths?
