mike smith1
| posted on 7/12/05 at 08:57 AM |
Fireblade Speedo Sensor
Hi
I have got the new style clocks of a 98 blade and my engine is a 97, i have a speedo sensor which mounts into the top of the gearbox, but because of
my year of engine i have to mount it external.
If i were to drill my drive adaptor and insert two magnets, would this have the same effect as the sensor being in the gearbox, or do i need to get a
toothed wheel e.g a cam wheel for the sensor to count??
Any help would be great if you can understand what im babblin on about!!
Cheers Mike
Avoneer
| posted on 7/12/05 at 09:10 AM |
Yep, it will work 100%, but don't drill your prop adaptor, just araldite two magnets to the sides of it and mount your sensor accordingly on a
little bracket.
Also, you WILL need a "Speedo Healer" or the like to fine tune/tweak,callibrate the speedo display.
Pat...
mike smith1
| posted on 7/12/05 at 09:15 AM |
Nice one, any ideas for were to get the magnets i've looked but had no joy!
Cheers Mike
Avoneer
| posted on 7/12/05 at 09:38 AM |
How does 6 x 1st class stamps sound in exchange for 2 magnets?
I've got a few spare you see as I had to buy 10.
Pat...
mike smith1
| posted on 7/12/05 at 09:46 AM |
sounds great send me your address on u2u and i'll put them in the post today!
Cheers Mike
ChrisGamlin
| posted on 7/12/05 at 10:50 AM |
FWIW I drilled my magnets partially into the prop adapter just to hold them in place a bit better (in conjunction with Araldite) because Ive heard of
them going AWOL before. You only need a very shallow hole about 6mm diameter to virtually make them a press flush fit, so it doesnt weaken the flange
in any way.
mike smith1
| posted on 7/12/05 at 10:51 AM |
I was thinking along those lines that way, you know at least it has got hold of it.
Cheers Mike
