Author: Subject: bike clocks
Taz Surfleet
posted on 11/12/05 at 07:49 PM Reply With Quote
bike clocks
coming to the stage where i need to buy a set of clocks for the indi, was wondering which bike clocks people have used that have an electronic speedo (ie not mechanical)?
ChrisGamlin
posted on 11/12/05 at 09:25 PM Reply With Quote
You'l most likely need to use the clocks that match the bike as a lot of them have feeds from the ECU for the temperature etc, you wouldnt necesarily be able to easily replicate these feeds if buying standard senders to get readings from.
Chris
G.Man
posted on 12/12/05 at 05:32 PM Reply With Quote
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=8017321057&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
Opinions are like backsides..
Taz Surfleet
posted on 13/12/05 at 11:33 PM Reply With Quote
cheers Chris Im using a gsxr1100 which unfortunatley uses a mechanical speedo gotta say that looks tempting Gman
Coose
posted on 14/12/05 at 08:47 AM Reply With Quote
It won't matter what you use with a GSX-R1100! And to be honest, that one on eSkip via GMan is smashing for the money! If I hadn't used R1 clocks and had of been around at the time I woulda gone for that!
Spin 'er off Well...
ChrisGamlin
posted on 14/12/05 at 12:21 PM Reply With Quote
Yep, what I meant was that the engine might not care, but the clocks possibly will, ie you probably couldnt use R1 clocks because the clocks would expect to see certain feeds from the ECU and from sensors that have a specific resistance range etc that you may not be able to easily replicate with off-the-shelf bits.
Taz Surfleet
posted on 27/12/05 at 11:55 AM Reply With Quote
G.man are the clocks still available ?
