Author: Subject: Calling all R1 bec
the moa 2
posted on 24/12/05 at 09:59 PM Reply With Quote
Calling all R1 bec
In the middle of sorting my R1 conversion and am still undersided on which gearlinkage system to go for so thought id re use this common post.
copy n paste......
Few Q&A's
1. What year and model of engine
2. What air filter set up
3. What exhaust system
4. What Diff and wheel sizes
5. What type of gear linkage - cable/solid links
the moa 2
posted on 24/12/05 at 10:04 PM Reply With Quote
1. not bought yet but was thinking carbs
2. Want to stick with original airbox (will this fit under the GTS taller bonnet ? )
3. Custom made equal lenth 4-2-1
4. I think its a 3.89 & 13 195 60
5. Was thinking cable as the RGB boys use it so must be the way to go.
Triton
posted on 24/12/05 at 10:10 PM Reply With Quote
Triumph Triple is a better bet as cheaper and make a mad noise......oh and it's British
www.tritonraceseats.com
www.hairyhedgehog.com
OX
posted on 24/12/05 at 11:44 PM Reply With Quote
yamaha R1 fuel injected,but id think twice about using the new 180bhp engine type .
not sure if the r1 air box will fit under your bonnet upside down.
if it doesnt use a sock filter
4-2-1 ,they look nicer and i believe they give better lower end response but i dont know if anyone can notice much difference
all i can say is shed has a 3.92 diff in his ri indy with 15inch wheels and 50 or 60 profile tyres and his car seems to be screaming every where.
i used a 3.62 and 17 inch wheels in my R1 indy and thought it was just right,
i did the solid link twice and cant fault it.
i think the cable idea is a good idea tho but iv heard and read of a few people changing back to solid link.
progers
posted on 25/12/05 at 09:55 AM Reply With Quote
1) I used a 2001 carb model in my original Indy - its a good motor.
2) Used a piper cross "sausage" filter, managed to get it to fit under the bonnet of the indy. I think you will be struggling with a GTS/Locost unless you have a scoop on the bonnet
3) Custom 4-2-1 its worth spending the extra money here as it definitely releases more horses :-)
4) I would recommend a 3.62 diff with the R1 (even though I used a 3.38) mainly as you can get an LSD relatively cheaply. I would not use a 3.89. I used 15" wheels with 195/50 tyres. Use that or 13" 185/80 (front) 205/60 (rear). Don't go 17" please (I won't say why as I'll go into rant mode)
5) I used cable. Mechanical or cable can both be good its really down to how well they are implemented. Cable needs to be short and mounted on substantial brackets to eliminate flex.
Other things :-
Uprate the clutch (remove the anti-judder mechanism and replace with standard friction) and beef up the spring
Fit a baffle plate
If going Carb make dure you rejet it properly before givingit any stick. Try and source a 200/2001 motor if you can. They are significantly stronger in the clutch/gearbox than earlier models.
Paul
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
Building: a pile of bits that will someday be a fisher fury
posted on 25/12/05 at 08:16 PM Reply With Quote
1. 2005 172bhp one (havent bought it yet but will be in the next month or so) there seem to be a fair few new engines with only a couple of hundred miles on them for not too bad money)
2. im going for a custom airbox ducted to a vent near the front so cool air plus less noise as i dont want to be caught out on any trackdays with low limits
3. 4-2-1 possibly using richard miles's design or one tweaked to remove the flat spot of the new engine round 7k rpm.
4. 13" 185/80 (front) 205/60 (rear) with a 3.2 freelander, 3.38s are too rare so im not holding out much on getting one and the 3.62 is a bit short for motorway use (im building a fury so aero body and a curved windscreen should make it more civilised at high speeds)
5. cable with proper brackets should feel direct enough.
speed8
posted on 26/12/05 at 05:24 PM Reply With Quote
2003 R1
Don't know yet but likely ITG
Probably Richard Miles design
13's with 185/70 on front and 205/60 on rear
Solid
Edited because I read the last question as throttle linkage..... too much christmas spirit!!!
[Edited on 12/26/05 by speed8]
Bob C
posted on 26/12/05 at 07:15 PM Reply With Quote
1) 99 carbs
2) tbd - pipercross probably
3) MK 421
4) 3.14 - 14"
5) rods & rosejoints!
Bob
Coose
posted on 28/12/05 at 10:54 AM Reply With Quote
Mine's an '01 (carb). It's up to you really! Don't forget the baffle plate (available from various sources - mine's a JB7). I wouldn't bother touching the clutch until you wear out the existing one - mine has had 3000 miles of abuse and is still absolutely fine! Why replace something when you don't need to? I'd recommend sticking with genuine plates though when you do - they really can't be beaten!
I have a Pipercross 'sausage' type, with a TTS jet kit. It works superbly, though I have a set of Keihin FCR flatslides for it too, which I haven't yet got around to trying....
Mine is a bespoke 4-2-1 to Rich Miles 'All-bikes' design. It works beautifully, looks superb and cost just over £400. I'd say it was worth it!
I use a 3.54 diff (live axle), though I had the original 3.89 in for a bit. It went like stink but topped out at 110-ish! I'm using 205/60-13's on the back. I think that 13's look sooooooooo much better than 15's! (hopes not to start a 'discussion' with that statement! )
Solid rod paddle shift. You'd be daft not to, bearing in mind the location of the gearchange shaft on the motor! Mine consists of two rods, a bell-crank, the paddle, four rose joints and a home-made bush for the bell crank. It works great, with no backlash and instant gearchanges, and has to be more reliable than the electronic one's! (Hopes not to start a 'discussion' about that either.... )
[Edited on 28/12/05 by Coose]
Spin 'er off Well...
ChrisGamlin
posted on 28/12/05 at 03:48 PM Reply With Quote
2003 FI "5PW" engine
Currently an open sausage filter (ITG) but I'll be fitting a custom airbox before it ets rolling roaded to keep trackday noise down
Custom made 4-2-1 system built to British Superbike spec lengths
3.54 Live axle with 185/60-13" tyres, although it could do with 205's for faster circuits as it currently tops out just under 120mph
Solid, using a very simple bell crank arrangement (pics in photo archive)- the R1 has such a well positioned gear change arm, making it more simple than most others to get a linkage on it. A friend converted his Westie blade from linkage to cable and is now converting back again because he doesnt like the feel of the cable.
[Edited on 28/12/05 by ChrisGamlin]
the moa 2
posted on 28/12/05 at 08:31 PM Reply With Quote
COOSE
Do you have any pics of your paddle shift or any advice on how to make one ie rod lenths etc and how or where you got the actual steering paddle part?
skydivepaul
posted on 28/12/05 at 10:42 PM Reply With Quote
1. What year and model of engine '99 carbs
2. What air filter set up. standard air box and filter but will be upgrading to a K&N, I have been recommended to keep the existing air box as they flow better than a a TTS type filter. will have it rejetted and rolling road set up at the same time. The airbox fits under the MK bonnet with bulge. See pics
3. What exhaust system. MK 4-2-1
4. What Diff and wheel sizes 3.89 and 15" with 195-50-15 yokos and Avpn ACB10 for track days
5. What type of gear linkage - solid link tunnel mount. works great, but i might upgrade to a solid link on the steering column.
cheers
Paul
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
Coose
posted on 29/12/05 at 11:46 AM Reply With Quote
There are a couple of pics of my linkage here....
http://www.ne7ers.co.uk/modules.php?set_albumName=albun01&op=modload&name=Gallery&file=index&include=view_album.php
I used an equal length bell crank, and if I remember rightly the rod from the paddle is something like 100mm from the pivot centre. I'd have to measure it again to be exact. I have a luvly JB7 milled ali paddle to go on there, which I haven't got around to fitting yet - the one in the pics was knocked together to test it and has never been changed!
The paddle doesn't rotate with the wheel, but it doesn't need to - I'm using a 2.5 turns rack and the paddle has never been easily out of reach!
I'd highly recommend going down a similar route, as like I said, which the gearchange shaft on the motor being where it is you'd be daft not to!
the moa 2
posted on 29/12/05 at 10:06 PM Reply With Quote
It look so simple !
But im sure its not .
How much pressure do you have to use to change the gears, Could you just use a couple of fingers or does it need the hole 4 ?
Coose
posted on 4/1/06 at 08:51 AM Reply With Quote
It's very simple indeed! What you see is what you get!
I use probably two fingers, though they are third and little fingers. You can easily use one though....
jimgiblett
posted on 4/1/06 at 04:53 PM Reply With Quote
2003 Inj (5PW)
Modified Airbox
4-2-1 Powerspeed
3.38 hybrid LSD (14" wheels with 185-60-14)
5. What type of gear linkage - cable/solid links .
STM - Rose Joined Bar
