Author: Subject: Wiring up my R1 Inj 02-03 Phoenix
jimgiblett
posted on 27/12/05 at 10:46 AM Reply With Quote
Hi Guys,
I am just finishing of the wiring on the new R1 motor but seem to be
having a brain fade moment on the ignition switch.
There are five wires which link to the ignition key:-
A thick Red and a thick brown/blue. I have wired these either side
of the to the ignition key.
But there is also a three wire combo going to a red plug
(Blue/Yellow to starter relay assembley, Blue/Black (which becomes a
black and goes to the ECU) and a brown/red.
The brown/red looks to be just a live feed to the side lights so I
can ignore this but have you R1 Inj guys permanently spliced the
Blue/ yellow to Blue/Black (which becomes a black and goes to the
ECU).
Any help much appreciated.
Jim
speed8
posted on 27/12/05 at 11:25 AM Reply With Quote
Somebody told me to just splice the Bl/Y and Bl/B together. The sidelight wire was going to be removed to a switch.
I was going to do it slightly differently and have a single throw, double pole ignition switch so I could just hook everything up as in the wiring diagram.
[Somebody else will be along shortly to confirm or deny the bollox I'm spouting ]
ChrisGamlin
posted on 27/12/05 at 01:26 PM Reply With Quote
Hi Jim
Sorry I never got back to you on u2u, I read it, was going to look in the garage then forgot all about it and havent been into u2u since!
I cant remember what I did but Im out in the garage sometime this week probably (if its not too cold!) so I'll try to remember to have a look.
hope you had a good Christmas!
Chris
jimgiblett
posted on 27/12/05 at 03:54 PM Reply With Quote
Thanks Guys,
Splicing the Blue/Yellow and Blue/Black seems logical. If you get a moment to check Chris when you're next in the garage it will be much appreciated.
cheers
Jim
