chrisf
| posted on 27/12/05 at 09:26 PM |
Center bearing pics
Gents:
I'm finally at the stage where I need to finalize prop mounts and such (I've fretted and put it off for far too long!). I've seen
quite a few pics of Westies, etc and their center bearin mount pics, but none of self builts. For those gents who built their own chassis, will you
post pics of your prop's center bearing? A silly request, perhaps, but I've painted the chassis and need to figure out how to mount the
center bearing--hopefully without firing up the MIG gun.
Or do any of you innovative gents have a kind suggestion as to how to mount a center bearing on an already painted chassis?
--Many thanks, Chris
MikeR
| posted on 27/12/05 at 10:02 PM |
i guess you're going bike engined as all car engined 7's i've seen have used a one peice prop.
| posted on 27/12/05 at 10:03 PM |
the clues in the 'locost blade' bit
pathfinder
| posted on 27/12/05 at 10:13 PM |
I’ve just fitted mine (there are a couple of pics in my archive) I was going to bolt it to a large box section bolted onto the existing gearbox plate
but this seemed a bit overkill! I may add a gusset or two to stiffen things up, I will probably end up tacking those nuts onto the plate as well! Work
in progress so any opinions would be appreciated!
Avoneer
| posted on 27/12/05 at 10:31 PM |
I welded in a 6mm plate (200mm wide) in the tranny tunnel next to where the drivers left knee would be.
You don't want the centre bearing to wobble loose!
Pat...
