Author: Subject: Steering connecting rod too short?
Tinks
posted on 9/1/06 at 01:40 PM Reply With Quote
I have just tried trial fitting the connecting rod from the steering column to the sterring rack and it appears about 50mm too short. I have an adjustable Seirra steering column and a modified link from MK. Having looked in my Haynes manual (2004 print) I cannot find any reference to dimensions etc.... can anybody help Thanks in advance
zxrlocost
posted on 9/1/06 at 01:51 PM Reply With Quote
they may have done it wrong mate these things happen
Howlor
May be you have the first 'Stretch' MK?! Maybe the adjustable column is different but I believe the fixed column do have some adjutment if you slacken the aluminium cast clamp the hold the column to the car. The column slides a little in the clamp.
Tinks
posted on 9/1/06 at 02:14 PM Reply With Quote
Cheers Steve
I was just wondering if the column may have been in a shunt and the trianagular shaft has been pushed inside any thoughts ...?
mookaloid
posted on 9/1/06 at 02:36 PM Reply With Quote
Mk told me that you can get hold of the triangular bit with mole grips and pull it out a bit. that should sort it out.
Tinks
posted on 9/1/06 at 04:47 PM Reply With Quote
Thanks guys
