Author: Subject: r1 size of coolant hoses pretty urgent!
zxrlocost
posted on 19/1/06 at 10:02 AM Reply With Quote
alright can anyone remember what size coolant hoses I need for my 99 r1
anything will be helpful
so I can order the samco ones asap
I need engine and rad end
otherwise ill obviously measure them when I get home
ta chris
zxrlocost
posted on 19/1/06 at 10:15 AM Reply With Quote
so isnt there any reducers or
what about the small hose?ta mate
chris
progers
posted on 19/1/06 at 10:59 AM Reply With Quote
Hose sizes are documented on Rich Miles site under radiator/cooling system see :-
http://striker.r-one.co.uk/
Paul
Dillinger1977
posted on 19/1/06 at 11:02 AM Reply With Quote
connections on my r1 were 25mm. i used 32->25 reducers on mine only to connect to a polo rad. if you are using r1 rad im guessing there would be no reducers.
theres a pic here:
http://www.locostbuilders.co.uk/viewthread.php?tid=37045
-Rog
smart51
posted on 19/1/06 at 11:03 AM Reply With Quote
small breather hose out of a 98 thermostat is 5mm, as is the water pump breather hose
small water hose out of the oil cooler is 15mm.
The curved hose out of the top of the engine into the stat is smaller on the engine side than on the stat, but I don't know how much
zxrlocost
posted on 19/1/06 at 11:28 AM Reply With Quote
ok thanks everyone
Coose
posted on 19/1/06 at 11:41 AM Reply With Quote
Hoses out of head to the stat are 19mm.
Spin 'er off Well...
