Author: Subject: Electric Shifter
lsdweb
posted on 22/2/06 at 01:36 PM Reply With Quote
Electric Shifter
Hi
Not quite the same question as the other thread!
Whilst putting my single seater back together, we're debating whether to ditch a manual gear mechanism because space around the steering wheel is a bit tight (seriosly tight!).
Is anybody using just an electric shifter - I'd be concerned about selecting neutral as it's always on all the bikes I've ever owned been a case of nudgint the lever from 1st to neutral.
Regards
Wyn
mookaloid
posted on 22/2/06 at 01:42 PM Reply With Quote
I believe Tony - mk blade on here uses one.
You could try asking him
mark
tks
posted on 22/2/06 at 01:46 PM Reply With Quote
i made an complete home made system..
It does Clutch, Throttle, gear changes all electric..
sow once rolling i never touch clutch again...
and while shifting i always have the throttle... down...
its just what you like...
Tks
lsdweb
posted on 22/2/06 at 03:50 PM Reply With Quote
Thanks Guys
Tks - do you have any details / pictures?
Regards
Wyn
