Author: Subject: klicktronic gear change system
ch1ll1
posted on 24/2/06 at 01:58 PM Reply With Quote
any body tried one of these
sounds good
spoke to them (as i dont want a gear stick if i dont have to ),
they say they are very reliable (as they would)
ordered one. just recieved it today(next day very good service )
a little pricey though £499
just got to find time to fit it now
anyone had dealing with them or seen them in action?
cheers paul
http://www.kliktronic.co.uk/faq.htm
[Edited on 24/2/06 by ch1ll1]
Mike S
posted on 24/2/06 at 02:17 PM Reply With Quote
Hi Paul
I've got a Kliktronic gearchange on my GT-1. Not quite ready for SVA at the moment but engine running.
Have tried the gearchange and seems to work perfectly. I got no other gear lever so purely using the Kliktronic.
Just need to fit the ingnition interrupt for full throttle upshifts!!
Can't say yet how it works long term, but several others on here have used it with great success. I'm sure they will add comments.
Should be the nuts.
Be careful how you mount the solonoid unit, ensure that it is balanced and that the stroke length is correct, and you should be fine.
Mike
There are more horses' asses in this world than there are horses
welderman
posted on 24/2/06 at 02:18 PM Reply With Quote
Looked into it myself, keep us posted on your progress mate.
Thank's, Joe
I don't stalk people
ch1ll1
posted on 6/4/06 at 01:07 PM Reply With Quote
well got it up and running today !
it not as strong as you would think .
but once you read the book that comes with it (no sure what its called) it becomes clear !
just have to measure the distance from linkage
as it only travel 1 inch each way
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 6/4/06 at 03:55 PM Reply With Quote
I've got one on my Indy, coupled with an ignition interrupt to allow flat upshifts. took a bit fiddling to set up but works great now, reducing the transmission shunt by a large amount. a bit 'pose-y' but genuinely useful if doing drag strip dashes or track days.
[Edited on 6/4/06 by scotlad]
Ferrino
posted on 6/4/06 at 04:16 PM Reply With Quote
I bought one and have fitted it along with a Translogic flatshifter. I also have a mechanical gearshift as a backup in case the electronic shift fails. Have not road-tested it yet, but it seems to be pretty powerful from the tests I did in the garage! Took me ages to set it up with the correct throw (the force it provides is progressive, so you need to use the full 25mm travel for effectiveness). Just need to get a gaiter to protect the unit from crap/crud ingress as I have mounted it horizontally.
Be interested to see any pics of your installations.
