cloudy
| posted on 24/2/06 at 02:21 PM |
GSXR 1100 Speedo solution?
The speedo on my GSXR1100 is cable driven annoyingly (the next model is electronic) How do people generally add a speedo to their BEC? I'd like
a standard dial type if possible & cheap!
James
stevebubs
| posted on 24/2/06 at 02:38 PM |
Magnets on prop
toothed wheel on diff flange
Magnets on wheel
Magnets on driveshaft
take your pickk...lots of ways to crack this egg...
cloudy
| posted on 24/2/06 at 02:49 PM |
Sorry, I didn't make myself clear
I'm more concerned about the actual speedo dial itself, I'm sure I can mount an electronic pickup sensor easy enough....
James
| posted on 24/2/06 at 04:25 PM |
What's wrong with the original bike clocks?
cloudy
| posted on 24/2/06 at 04:38 PM |
nothing, but the speedometer is a mechanical version - I have no way to use this on the buggy
[Edited on 24/2/06 by cloudy]
matt_gsxr
| posted on 18/12/06 at 05:57 PM |
I know this question is old, but its new to me.
I have exactly the same problem. If you don't mind LCD numbers then it is easy (various bicycle speedos, acewell, or motorcycle clocks).
If you want actual "proper" dials, then you can buy new. There are various digital solutions, most of which will look after you when
setting up (the cheapest is from racetech at around £85), but ETB, CAI, greengauges, VDO, all have solutions. Looking around £130.
The "interesting" thing is that motorbikes went from cable driven, to LCD almost avoiding the servo driven ones completely. So there are
relatively few bikes that had servo driven speedos.
The short list includes:
sv650 and sv650s (98-02 models)
CBR600 some years
Even if you do manage to source one of these, then you still need to build some triggering hardware (magnets and reed switches, or hall-effect, or
something), and then you need to be able to build some electronics to convert the frequencies accordingly.
It is something that I am working on doing.
Matt
rf900rush
| posted on 20/12/06 at 10:27 PM |
Hi I had the Same Problem with my Suzuki RF900 engine
I used an ETB Speedo / Odo with 2 magnets on the prop.
Calculated the calibration value by measuring the rolling circumference + diff ratio and Passed the SVA easy.
Now going for a home made Digital Dash. (Search for digital dash)
Martin
