| posted on 26/3/06 at 04:52 PM |
bike starters
zx9 starter, is it constantly engaged? i cant see any way for it to disengage, plus when i kill the engine i can hear a starter sort of sound for a
split second before it stops spinning. Just thought id check!
hector
| posted on 26/3/06 at 05:00 PM |
yea they are always engaged on a one way clutch set up, its normal on some bike to hear that noise u say about its just the engine partially moving
back as it stops against compression.
NO Worries
cheers Colin
Nick Skidmore
| posted on 26/3/06 at 05:01 PM |
The starter motors on modern bikes are engaged with the crank or clutch basket via a sprag clutch which isolates the starter from the constant
spinning of the engine.
The sound you can hear is probably a bit of both sprag clutch and starter.
| posted on 26/3/06 at 05:09 PM |
cheers chaps
ChrisGamlin
| posted on 26/3/06 at 05:38 PM |
As a side note, thats the reason you need to be quick do dip the clutch if you spin a BEC because if the spin stalls the engine and the crank is
momentarily made to reverse by you travelling backwards, it will take out the starter motor and/or surrounding casing.
