lsdweb
| posted on 1/4/06 at 12:53 PM |
R1 Temperature Sender Fittings
Hi All
I need to fit two temperature sender adaptors to my R1 (ECU - electric 12mm and temp gauge - capillary). I want to fit these before the thermostat but
can't find any hose adaptors in such a small size (19mm approx).
Can anybody tell me how they've overcome this problem.
Many thanks
Wyn
[Edited on 1/4/06 by lsdweb]
ChrisGamlin
| posted on 1/4/06 at 01:46 PM |
Hi Wyn
I only needed to fit one additional sender (for my dash) but I got my uncle to weld me in a boss on like this....
  Digidash Temperature Sender
Iguess you could probably squeeze two senders onto that pipe
lsdweb
| posted on 1/4/06 at 03:40 PM |
Clever!
I could get a boss welded onto each of the outlets from the head.
Thanks Chris
ChrisGamlin
| posted on 2/4/06 at 03:40 PM |
Yep its a good place to measure from, you get a very direct reading straight out the head. I forgot about that second pipe cos Ive chopped that down
going into my head, so wouldnt be able to get a sender in there
[Edited on 2/4/06 by ChrisGamlin]
lsdweb
| posted on 4/4/06 at 09:21 AM |
Thanks Chris
Space is tight so I may end up chopping some pipes as well!
Wyn
