Author: Subject: another speedohealer thread!
posted on 8/4/06 at 10:00 AM Reply With Quote
hi chaps, loads of useful info in the archives about speedohealer, but i cant find how exactly i mount the speedo sender now it has a prop. Someone said i can use the bolts on the sprocket adapter, but magnets are normally mentioned. Any tips for an idiot?!
ReMan
posted on 8/4/06 at 10:05 AM Reply With Quote
What sender are you using?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
posted on 8/4/06 at 12:00 PM Reply With Quote
not sure, i probably have both the standard kwak one and a fazer one. Im guessing the standard zx9 one will be easiest.
ReMan
posted on 8/4/06 at 12:43 PM Reply With Quote
I tested an industrial generic one and found it fired my fireblade clocks, against steel ie bolt heads rather than actually needing a magnet to operate.
I now have a genuine fireblade sender, but have not tried it on a bench yet so am in a similar position to yourself.
If the blade one works on bolt heads, do I fit it near the 4 propshaft/diff bolts or the 6 driveshaft bolts or do I fit 2 or 3 magents somewhere?
I'm using a yellowbox healer and I dont think they have quite the adjustment range as the speedohealer.
I don't know wether this helps you much or not?
Colin
posted on 9/4/06 at 04:52 PM Reply With Quote
bumpety bump! So if i have a go with the original, how close should it be to the spinning bolts?! cheers.
ReMan
posted on 10/4/06 at 08:45 AM Reply With Quote
Within about 2 to 5mm, it was working
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
