Author: Subject: BEC Idle
chrisf
posted on 9/4/06 at 07:02 AM Reply With Quote
BEC Idle
Gents:
What is the typical idle RMP of a BEC--or more specifcally, the 'blade?
--Thanks, Chis
posted on 9/4/06 at 07:05 AM Reply With Quote
on cold start up i turn it up a little, maybe to 2k. Obviously its going to be a lumpy idle with no flywheel! You can turn it down again once warm, but i dont bother, id rather it idle high (afterall, its not idling much when being driven) and be a little harder to stall. Cant say for blade though.
posted on 9/4/06 at 07:49 AM Reply With Quote
Idle on the Blade should be 1,100 rpm (Plus or minus 100)
Phil
gingerprince
posted on 9/4/06 at 07:59 AM Reply With Quote
Should be about 1100, but mine wouldn't tickover at that until I balanced the carbs.
chrisf
posted on 9/4/06 at 03:02 PM Reply With Quote
Thanks guys.
--Chris
shortie
posted on 9/4/06 at 03:58 PM Reply With Quote
1100 give or take 100 rpm.
BTW, did the rectifier wiring work ok???
Rich.
chrisf
posted on 10/4/06 at 03:23 PM Reply With Quote
Hi Shortie:
I didn't want to jinx myself yesterday...Yep, the rectifier wiring worked--seemingly--perfectly! I drove the car on and off for two hours yesterday, and each time, it started fine. I did use a new battery, but I have a hard time believing that a little battery can supply spark for that long. I also noticed that I can acually tough the rectifier without getting burned. The old blade bit was very, very hot.
I cannot thank you enough for your help on that one!
--Thanks, Chris
[Edited on 10/4/06 by chrisf]
shortie
posted on 10/4/06 at 09:39 PM Reply With Quote
That's brilliant mate, really happy it worked, amazing how much better they are!!
Rich.
