Author: Subject: First drive
wheezy
posted on 14/4/06 at 03:37 PM Reply With Quote
First drive
Well took the car out for its first drive now that I have a exhaust fitted (many thanks Martin).
You can just feel the engine wanting to go.
No problems moving of from a standstill the hyd clutch works like a dream. The only problem was the accelerator pedal, you just have to touch it and the engine revs like mad.
I may have to increase the pedal travel but never having driven a BEC before i dont know how much travel there should be.
How much pedal travel from idle to fully open do people have?
stevec
posted on 14/4/06 at 03:47 PM Reply With Quote
What a lovely looking car, Nice colours.
My trotter pedal is very light and has no feel, I am going to increase the sping load at the pedal end somehow.But travell is fairly like any car I would say.
owelly
posted on 14/4/06 at 03:53 PM Reply With Quote
Try driving in your socks! seriously!
http://www.ppcmag.co.uk
Russ-Turner
posted on 14/4/06 at 03:56 PM Reply With Quote
I was just about to say that myself.
wheezy
posted on 14/4/06 at 04:11 PM Reply With Quote
Originally posted by chris mason
thought you was going to wait till the weekend
nice car looks even better in the flesh
Chris
Once I fitted the seats temptation got the better of me
Thanks for the nice comments it makes months of work all worth while.
shortie
posted on 14/4/06 at 06:34 PM Reply With Quote
Not sure what engine you have but on the blade the bike trhottle connection at the carb end has a return cable. Basically I just replaced this with a spring so that there is more feel as when you press the acc pedal you are pulling against the spring .
Hope that makes sense!!
Rich.
wheezy
posted on 14/4/06 at 06:50 PM Reply With Quote
I have a ZX12 fitted and on the bike it has a similar return cable.
I dont have any problem with the feel of the accelerator just the overall travel of the pedal.
From idle to fully open the pedal only moves just over 40mm.
shortie
posted on 14/4/06 at 06:55 PM Reply With Quote
Probably just need to get used to it then, I'm sure you'll be fine.
BTW, car looks ace, love the colour!
Rich.
wheezy
posted on 14/4/06 at 07:00 PM Reply With Quote
You cant realy go wrong with the gulf colours on this shape of car.
Dave
wheezy
posted on 15/4/06 at 08:27 AM Reply With Quote
So i take it that 40mm pedal movement is about the same as everyone else?
posted on 15/4/06 at 09:35 AM Reply With Quote
i have more like 80mm, but thats with a long top mounted pedal.
wheezy
posted on 15/4/06 at 04:54 PM Reply With Quote
With the pedal movement I have at the moment I get about 3000 rpm with only 10mm of travel which feels like an on/off switch. I didnt want to drill more holes in the bulkhead only to find that I need to re- educate my right foot
russbost
posted on 16/4/06 at 10:03 PM Reply With Quote
I have about 80mm+ & progression is sensible, I can drive in steel toecap workboots no problem!! I have disconnected return cable & use return spring instead
wheezy
posted on 18/4/06 at 08:54 AM Reply With Quote
Going by everyones replies I have taken the plunge and moved the cable closer to the pedal bearing. I now have about 60-70mm travel and the throttle response is more controlled. I just need to connect an additional return spring before I take it out on another test drive.
TimC
posted on 18/4/06 at 09:16 AM Reply With Quote
Wow! Who did your paint? Must be worth a plug....
Fred W B
posted on 18/4/06 at 11:25 AM Reply With Quote
I'd agree on the excellent paint scheme. It looks a thousand times better than the multicolour scheme on the show car in your archive.
Are you still going to fit a rollbar?
Fred WB
wheezy
posted on 18/4/06 at 01:12 PM Reply With Quote
It was the bodywork and the chassis from the show car that I bought. The multi-colour paint scheme was removed after the show.
I have just fitted the role bar which Martin at MK Engineering made when he was manufacturing the exhaust.
I will post some more pictures in the next few days.
Dave
