Gav
| posted on 8/5/06 at 02:29 PM |
Clutch/Accelerator cables
Hi Guys,
Im planning on using push bike brake bable for the clutch and accelerator cables.
Anything good/bad/ugly about using these types of cables i should watch out for?
Gav
| posted on 8/5/06 at 02:41 PM |
Well my thought process was a bike clutch is going to need a lot less pressure to operate than you would apply if it using as a brake cable on a push
bike, but then again i canrt remember the last time i was on a push bike!
zxrlocost
| posted on 8/5/06 at 02:50 PM |
accelerator cable fine same as what I have done works a treat dont forget to grease the inside to help it a bit
clutch cable idea will just snap in two they are under some right pressure
use the bike clutch cable
Aboardman
| posted on 8/5/06 at 04:48 PM |
if you can fit twin accelerator cables just in case one breaks like mine did, but with the bike carbs it may be more difficult.
Bob C
| posted on 8/5/06 at 05:11 PM |
motorbike shops sell 'generic' clutch cables for just a few quid - might as well get one of them. I used bike cable for throttle - the
nipple on the end needed just a little filing to fit nicely in the carbs!
Bob
ch1ll1
| posted on 8/5/06 at 07:55 PM |
i used on bike cable on my old gsxr,
last about 1/2 our outer cable squashed
no good
