Author: Subject: Tax
dave1888
posted on 10/5/06 at 08:07 PM Reply With Quote
Tax
So how much does it cost to tax a bec.
ChrisGamlin
posted on 10/5/06 at 08:10 PM Reply With Quote
It might be different if a kit is registered on a brand new plate (?) but most if not all fall into the same bands as any other pre 2001 car, so its considered the same as any other 1000cc car, which I think last year was ~£110 for a year.
DaveFJ
posted on 11/5/06 at 07:44 AM Reply With Quote
it's all on emmisions now
info here linky
ALL cars registered after March 23rd 2006 with more than 225g/km £210 per year
[Edited on 11/5/06 by DaveFJ]
Dave
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
Building: a pile of bits that will someday be a fisher fury
posted on 11/5/06 at 07:46 AM Reply With Quote
but g/km of co2 isnt tested at sva is it so it cant be emissions related.
DaveFJ
posted on 11/5/06 at 07:51 AM Reply With Quote
it's taken from the tables laid down by VOSA. if your car isn't listed then I beleive you come under the visible test category (same as cars registered before March 2001) so £110 up to 1549cc or £175 over 1549cc
how is that fair when a smoky old banger costs £50 a year less to tax than my 3 year old tin top running unleaded and a cat ?
I know that a car engined kit car is taxed based on the rating for the engine donor... however there is nothing to say what a BEC should pay - I have actually contacted VOSA about all this so will let you know when/if they reply!
Dave
watsonpj
posted on 11/5/06 at 11:40 PM Reply With Quote
Tax
my blade is £110 just paid it last week on the web.
DaveFJ
posted on 12/5/06 at 03:59 PM Reply With Quote
had an answer from DVLA - they said f*ck knows ask VOSA....
had an answer from VOSA - they said f*ck knows ask DVLA (but maybe it is checked at SVA)..........
so answer is 'f*ck knows'
ain't they great!
Dave
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
posted on 12/5/06 at 04:52 PM Reply With Quote
to get an accurate co2/km value you would have to put the car on a rolling road and run in though a set test procedure (ie to simulate road driving) whilst testing emissions. the tests manufacturers have to do is very long and it would be impractical to do that for every car.
you cant even take the manufacturers numbers for cecs as many engines are found in different models all of which have different ratings and as weight has a massive effect, kit cars should be much more efficient than the donor.
