Robert Ryan
| posted on 15/5/06 at 07:50 PM |
Spark Plug Leads
I am fitting a R1 engine to my MNR, anyone know where I can buy exstended spark plug leads. And at what sort of price.
Thanks Rob
| posted on 15/5/06 at 08:01 PM |
Not sure they have 'leads' as such... I think each spark plug has it's own coil pack therefore no need with special spark plug
leads. It may depend of year of engine... so check that out first! HTH
G.Man
| posted on 15/5/06 at 08:43 PM |
Buy a length of supressed HT lead, and unscrew the stock leads from the coils (you will have to break and remove the epoxy holding them in
first)...
Screw in the newuns and redo the epoxy...
Opinions are like backsides..
OX
| posted on 15/5/06 at 08:54 PM |
[Edited on 15/5/06 by OX]
G.Man
| posted on 15/5/06 at 09:07 PM |
Did I beat you too it
OX
| posted on 15/5/06 at 09:28 PM |
yes
Robert Ryan
| posted on 15/5/06 at 10:21 PM |
cheers
RichieC
| posted on 16/5/06 at 08:00 AM |
Or alternatively just mount the coils nearer to the engine on a bracket. Plenty of peeps have done this and it seems to work fine. Certainly saves
having to risk breaking the coil pack when you crack the epoxy off.
Rich
zxrlocost
| posted on 16/5/06 at 08:45 AM |
my coils are mounted on my r1 airbox
Ferrino
| posted on 16/5/06 at 09:24 AM |
I had nowhere suitable to mount my R1 coils (99 carbed engine) without getting longer leads, so I bought some PVC-copper-core HT lead from Vehicle
Wiring Products (58p/metre) and epoxy'd them into the coil packs as mentioned above and suggested elsewhere. I was told that a copper conductor
was the best to go for. You need to be a bit brutal to get the stock leads out of the packs (you have to break the little plastic 'tags'
but they will come free!
Which reminds me - how can I check with a multimeter that I have made a good connection between HT lead and coil pack?
[Edited on 16/5/06 by Ferrino]
tks
| posted on 17/5/06 at 10:53 AM |
Check for resistance
the simples way is measure every way you can, but do it on both coils (the new/recon one and a old good one).
that way you are sure they are identical if it is measureable...
in fact i have no idea what the secondary coil side is attached to.
Sow suggest just start and try!
Tks
asn163
| posted on 18/5/06 at 07:11 AM |
Ferrino,
Is the HT cable supplied by VWP marked as per SVA requirements?
Simon
Ferrino
| posted on 18/5/06 at 10:06 AM |
quote: Originally posted by asn163
Ferrino,
Simon
I don't think it is marked with anything.
