Author: Subject: ZX12r oil pressure
athoirs
posted on 20/5/06 at 02:03 PM Reply With Quote
ZX12r oil pressure
hi guys,
Have managed to fit up a SPA dual gauge to me an old oil pressure sensor using op-amps!)for my ZX12r engine and have being playing around with the callibration.. looking at the manual it says 23 (yes!) 23 psi at 4000 rpm @90c !!
Now that seems a bit low to me and just wondered if anyone else has measured the oil pressure or has a gauge fitted to their engine...
posted on 20/5/06 at 03:58 PM Reply With Quote
Does seem a little low - we're just about to fit our Spa Gauge (ah-hem) we'll let you know...
ChrisGamlin
posted on 20/5/06 at 04:09 PM Reply With Quote
How are you planning on calibrating it, and out of interest why can't you use an SPA sender?
athoirs
posted on 20/5/06 at 04:39 PM Reply With Quote
Well managed to aquire a gauge but no senders.. a new spa pressure sender will set you back about 80 quid! and I am a tight arsed scotsman. It gives out a 1v to 5v signal and not a resistance like most senders. You can set up just about anything with the software built into the gauge ( span, offset, alarms, ) it is the dogs of gauges
[Edited on 20/5/06 by athoirs]
ChrisGamlin
posted on 20/5/06 at 05:33 PM Reply With Quote
Ah ok fair enough, didnt realise they were that expensive just for the sender
Were you planning on calibrating it on your engine then, or something a bit more controllable / accurate?
[Edited on 20/5/06 by ChrisGamlin]
G.Man
posted on 21/5/06 at 08:26 AM Reply With Quote
I have set my dry sump regulator to that setting, and its incredible how much higher it goes when the revs pick up..
Runs about 60 psi most of the time...
Opinions are like backsides..
athoirs
posted on 21/5/06 at 11:55 AM Reply With Quote
thats good to know
I have a 0 to 100 psi gauge i am going to tee off the sender supply to set it up. Am not too concerned about the accuracy its more to show any change in pressure which i am sure you agree is more important. the gauge also records the lowest measurement taken which is what I really need with this engine
