Deckman001
posted on 31/5/06 at 09:50 PM |
R1 start switches ? ( it now runs !! )
On the R1 wiring Diagram I have, the start switch is two black wires, are they 'made' to start or 'broken' to start ?? Also
there are another two pairs in the same area, both made or broken circuits ?? any one remember, Sadly I don't have the diagram infront of me to
help with descriptions
Ignition switch is sorted by the way
Jason
[Edited on 31/5/06 by Deckman001]
[Edited on 2/6/06 by Deckman001]
MartinDB
| posted on 31/5/06 at 10:32 PM |
On mine ('02) the wire from the relay assembly is shorted to earth to turn the starter.
Martin.
[Edited on 31/5/06 by MartinDB]
Deckman001
| posted on 31/5/06 at 10:40 PM |
Excellent that's 1 confirmed , 1 of the others is 'stop' know if this is a perm connection, or 'made' to stop ??
Jason
MartinDB
| posted on 31/5/06 at 11:56 PM |
Stop as in kill switch? Red/black and Red/white (according to the US diagram I have here) ?
You can connect them permanantly, or wire them via a switch for security.
I've connected mine across the NC terminals on a FIA cut-off switch.
Martin.
Ferrino
| posted on 1/6/06 at 04:28 PM |
yes, stop switch is opened to kill the engine, closed to run.
Deckman001
| posted on 1/6/06 at 07:34 PM |
Cheers guys, I might get it started for him next week at this rate
Jason
Deckman001
| posted on 2/6/06 at 05:44 PM |
A Thanks to those that gave the advice on the switches, tries it this afternoon, and after 10 mins realised it had a clutch switch as well !
Do'h , then it started first time   Customer is a very happy bunny
It's nice when a plan comes together
Jason
Ferrino
| posted on 5/6/06 at 09:42 AM |
lol, was just browsing your photo album and spotted the piccie of Charlotte Hudson - used to have a major crush on her in Watchdog
Deckman001
| posted on 5/6/06 at 07:00 PM |
he he she's still on the box, Brainiac or something like it allthough she don't smile as much as she used to
Jason
adrian
| posted on 5/6/06 at 09:38 PM |
sorry guys back to the first post is it the blue/ yellow wire from the relay that is connected to the black wire in the red plug? should this be a
permanent connection? im a bit stuck thanks
Deckman001
| posted on 5/6/06 at 10:01 PM |
I think it was two reds I joined, but this was after extending them, D'oh I'll have to have a look when i get back to the car, sorry
If you look on the wiring diagram, it shows what colours go to the stop switch, just perm join them, or take them to a remote kill switch
Jason
adrian
| posted on 6/6/06 at 08:24 PM |
thanks, its actually the wiring going to what would have been ignition barrel on the bike im stuck with, ive sorted the kill switch. there are four
wires going to a red connector, not sure what to do with the 2 thin cables?
Deckman001
| posted on 6/6/06 at 09:56 PM |
wiring diagram for a 2003 model is,
Red Main Feed
With ignition in 'ON' poss you will have to have Red,Brown and Brown/red conected to each other
Two other wires that need connecting to each other when ignition is 'ON' are Blue/black and Blue/yellow.
Hope this helps
Jason
