| posted on 1/6/06 at 12:47 PM |
ZX12R Oil Pressure
There is a blank hex plug on the ZX12R engine which plumbs straight into the main oil gallery, so assume that this is the ideal place to mount the oil
pressure sender. The temperature will be taken from a sender mounted on the sump. Has anyone else mounted a SPA pressure sender in the same location
on the ZX12R and if so, was an adapter required to fit it? Any advice appreciated.
Phil
athoirs
| posted on 1/6/06 at 01:07 PM |
hi Phil,
I removed the oil pressure switch on the other side ( I am not using the zx12 clocks) and took a braided feed off that to the new oil pressure sensor
it was m10x1
I would say that was the best place as its at the other end of the same oil gallery
