Author: Subject: which fuel pump? yamaha r1 02/03 injection engine
adrian
posted on 4/6/06 at 12:25 PM Reply With Quote
hi what fuel pump should i use for my o2/03 fuel injected r1 and should i connect it to ecu or permanent live with ignition on?
speed8
posted on 4/6/06 at 01:51 PM Reply With Quote
I've put the original in the fuel tank. Seems to be pressuring up ok but I haven't been able to start the car yet (I might have made a little mistake in the wiring somewhere).
ChrisGamlin
posted on 4/6/06 at 02:58 PM Reply With Quote
The original pump is obviously fine but compared to an inline pump, its a pain to fit as it needs mounting into the base of the tank.
I fitted a Bosch pump model number 0 580 464 038, as also used by several other Injected R1 owners so fairly proven now. Mine was new off Ebay for ~£70 although its also used for Rover V8 Range Rovers / TVRs, and 405 MI16 Pugs amongst others, so you might find one in a scrapper somewhere.
cheers
Chris
adrian
posted on 4/6/06 at 03:32 PM Reply With Quote
thanks that sounds GREAT no messing about!
tks
posted on 4/6/06 at 06:32 PM Reply With Quote
i just used a sierra one from the scrapyard
its a bosch one and if you take it away
take also the complete holster,
then fitting it will be 3drills and 3 pops..and then it it nice in his rubbers...
Tks
