adrian
| posted on 7/6/06 at 08:28 PM |
r1 02/03 ignition wires to red plug?
hi im a bit stuck wiring my ignition (fuel injected r1, ive sorted the stop switch. the bit im stuck on is the red plug which would have gone to the
ignition barrel on the bike , there are three wires brown/red blue/yellow and a black/blue, what do i do with them?
[Edited on 7/6/06 by adrian]
adrian
posted on 8/6/06 at 05:55 PM |
can anyone help
JoaoCaldeira
| posted on 8/6/06 at 05:59 PM |
Hi.
I'm not near my engine. As soon as I take a look at it I'll get back to you.
Joao
Coose
| posted on 9/6/06 at 04:57 PM |
Looking at the wiring diagram you should have two plugs each with two wires going to the ignition barrel. One plug (colour of plug unknown) should
have a red wire and a brown/blue, and the other plug (red) should have a black/blue and a blue/yellow.
You should then join the red and brown/blue together, and then the black/blue and blue/yellow together seperately. This should bring on your ignition
and also power for lighting etc.
[Edited on 9/6/06 by Coose]
Spin 'er off Well...
JoaoCaldeira
| posted on 10/6/06 at 11:22 AM |
Hi.
Red connector:
Blue/red and Blue is for PARK circuit, IIRC
Black --> Blue / Yellow
Main switch (White connector)
Brown / Blue --> Red
Blue connector [59]
Red /^Black --> Red White (Engine kill)
Blue connector [11] (Side stand)
Black --> Blue / black
[41] (Left handlebar)
Blue / Yellow -> Black yellow (Clutch)
Green connector [52] (Fuel pump)
To a new relay to command the fuel pump
Red / blue --> 85 (signal)
Black --> 88 (ground)
Best regards,
Joao
adrian
| posted on 18/6/06 at 11:00 AM |
so do i permanantly join together the blue/yellow and black (black/blue on some looms) wires or should they be via a switch? ive cut out the lighting
circuits
JoaoCaldeira
| posted on 19/6/06 at 01:00 PM |
Just cut the wires...
I've cut all the lighting related wires and loom got quite thinner
Joao
