Author: Subject: Digi dash 2 lite gear indicator
R1 STRIKER
posted on 12/6/06 at 10:08 PM Reply With Quote
Finally got speedo working and yes it was polarity of magnets (my old gauges must have been opposite) but having some trouble with gear indicator it just seems to flick between gears. Somtimes 2 OR 3 either side of the actual gear.
Any ideas.
Ben.
Jon Ison
posted on 12/6/06 at 10:21 PM Reply With Quote
Is the speed reading steady ? I have only ever had very minor problems like yours sometimes hovering in between 5&6 when going slowly in 6th ?
I would guess it as too be speed output related.
R1 STRIKER
posted on 12/6/06 at 10:25 PM Reply With Quote
The speed does seem a bit sensitive. Have checked against GPS and is quite accurate but is very difficult to hold at a constant speed.
Ben.
G.Man
posted on 13/6/06 at 03:46 AM Reply With Quote
Gear indicator is only accurate when the clutch is engaged...
If you have your foot on the clutch then it will be all over the place as its a calculated indicator...
Opinions are like backsides..
