adrian
| posted on 11/7/06 at 09:00 PM |
r1 injection automatic choke
hi does anyone know how to plumb in the automatic choke on a fuel injeted r1?
ChrisGamlin
| posted on 11/7/06 at 09:08 PM |
Yep, the feed for it comes from the little pipe T'ing off the water pump inlet pipe (under the sprocket / gearbox output). That goes through the
"choke" and the outlet goes under the throttle bodies back into the top of the engine if I recall correctly.
Chris
adrian
| posted on 11/7/06 at 09:46 PM |
thanks chris, i noticed on the bike it had a t-piece running to top of rad , can i ignore this and connect it directly to choke like you said?
ChrisGamlin
| posted on 11/7/06 at 09:54 PM |
I suspect that T probably also bleeds back to the expansion tank, but Ive just plumbed mine as described above and its not caused a problem (I didnt
have a T on my engine so didnt know at the time!)
adrian
posted on 11/7/06 at 09:58 PM |
that will do nicely, thanks alot!!
