Author: Subject: r1 output shaft angle
martinste
posted on 13/7/06 at 07:30 PM Reply With Quote
The questions start.....
I have just started fitting my R1 cradle, MK cradle and Indy chassis. My question is does the engine, ouput shaft/adaptor have to be parallel to the diff input flange? Mine is not by a fair way.
Cheers Martin
rayward
posted on 13/7/06 at 07:32 PM Reply With Quote
just been speaking to a prop manufacturer today, and they said more than 1 degree but less than 3 ??.
Ray
martinste
posted on 13/7/06 at 07:52 PM Reply With Quote
Thanks for that, will have a measure tom. Am thinking adjustmants will be required...
martin
martinste
posted on 13/7/06 at 07:53 PM Reply With Quote
oops bad spelling. 1/10.
posted on 13/7/06 at 08:18 PM Reply With Quote
If it's a standard R1 engine installation, I wouldn't be too concerned. MK have doing R1 cradles for the Indy chassis for years now without any problems.
Phil
Coose
posted on 14/7/06 at 07:46 AM Reply With Quote
As I said to Martin, in a live-axle BEC the flanges will never be parallel anyway so it shouldn't really matter in an IRS car anyway!
So long as your prop shaft is well balanced and the UJ angles aren't excessive it shouldn't cause a problem.....
Spin 'er off Well...
