Author: Subject: Blade Oil Drain Plug
Jubal
posted on 14/7/06 at 02:48 PM Reply With Quote
Hmm, I've managed to strip the thread on the drain plug on my modded blade sump. Too much oil around and too eager with the wrench on the bolt my fellow locoster had welded in there. I'm gonna run a tap through the thread and take the risk of any swarf. Am I mad? Failing that, spare standard sump pan sitting in the garage is going on tonight.
Dunno why I'm posting as I have a plan but it helps to share!
Coose
posted on 14/7/06 at 03:16 PM Reply With Quote
Do you have any idea what size the thread is? I'd recommend dropping off the sump and helicoiling the thread.
The kits for large threads aren't cheap (see here ), so you may find a local engineering place that will bang you one in for half the price. Otherwise, drill and tap it the next size up. Halfrauds do a range of replacement car sump plugs so you may find one that you can use there....
[Edited on 14/7/06 by Coose]
Spin 'er off Well...
posted on 14/7/06 at 04:21 PM Reply With Quote
Put the standard sump back on while you get the old one fixed. Just get the stripped hole welded up, then drill and tap a new one.
Phil
Jubal
posted on 14/7/06 at 06:38 PM Reply With Quote
Sound advice chaps. Just off out to do the job now...
