xico_ze54
| posted on 20/7/06 at 09:59 AM |
What kind of diff is this?
Anybody can tell more about this transmission I don't know nothing. What type, brand, how it works...
Amadeu
Minicooper
| posted on 20/7/06 at 10:13 AM |
It's a FWD Ford Escort/Fiesta diff which has been converted to run outside the gearbox with sealed bearings, bearing mounts and a top hat thing
to seal the differential for oil/grease
I think that particular diff/driveshaft setup is from an XR2 and it's non-lsd but it doesn't matter
[Edited on 20/7/06 by Minicooper]
xico_ze54
| posted on 20/7/06 at 10:26 AM |
Thks David, can you tell me if that conversion is simple to do, or there are any manufactors that sell it already modified? Anyone that can make a
sketche to do the conversion DIY?
Thks
Amadeu
cloudy
I'm putting my chain drive together with the standard cossie limited slip diff used in the 7 kits, just removed from the casing - fitted with a
custom sprocket with a top hat to keep the grease in
James
www.warnercars.com
Danozeman
| posted on 20/7/06 at 11:03 AM |
Dont MK do the chain drive diffs with mountings??
Dan
Avoneer
| posted on 20/7/06 at 11:21 AM |
MK Engineering do I think.
Pat...
SeaBass
| posted on 20/7/06 at 11:48 AM |
In Scotland;
http://www.westgarage.co.uk/page4/page9/page9.html
cloudy
| posted on 20/7/06 at 12:38 PM |
by building it from donor parts, mine has cost me £120 for the cossie rear axle inc diff and £35 for the custom sprocket. I couldn't find any
other solutions for under £500
James
www.warnercars.com
tks
| posted on 20/7/06 at 01:07 PM |
is it optical or does that car have the diff
wronly mounted (angled??)
anyway doesn't matter
Tks
tks
| posted on 20/7/06 at 01:18 PM |
35 pounds for the sprocket!!
way to much
Minicooper
| posted on 20/7/06 at 02:09 PM |
Tks
I seen a few piccies of this car, the diff always looks as if it's been pulled out of alignment
The box section he uses is tiny, I would be very surprised if it didn't move
PS ZCars will also sell a modified sierra diff circa £500
cloudy
| posted on 20/7/06 at 11:53 PM |
way to much
If you know somewhere cheaper who will machine a 521 sprocket in a 50 tooth size with a custom bore & mount holes (including postage) - please do
point me their way!
[Edited on 20/7/06 by cloudy]
russbost
| posted on 23/7/06 at 02:18 PM |
£35 is about what I paid for my sprockets, I'd be surprised if you can find anything custom machined cheaper.
