Author: Subject: whats so good about the freelander diff
zxrlocost
posted on 21/7/06 at 11:19 AM Reply With Quote
hi
as above I know its lighter
(is it much lighter)
are all the ratios the same on all diffs
Ive read some previous posts
with a bit of confuison
so whats so good about the ratio ie is it better for acceleration or top speed etc
thanks chris
zxrlocost
posted on 21/7/06 at 11:22 AM Reply With Quote
sorry I dont mean is it much lighter I mean is it much smaller
JAG
posted on 21/7/06 at 11:44 AM Reply With Quote
I think it also has very low ratios suitable for bike engines. Around the 3.0:1 - 3.4:1 range I think.
Justin
Avoneer
posted on 21/7/06 at 11:49 AM Reply With Quote
IIRC, loads lighter and better ration for BEC's.
3.1 rings a bell.
Better for top end.
No need to worry about acceleration on a BEC!
Pat...
posted on 21/7/06 at 01:23 PM Reply With Quote
Westfield do a 3.2:1 LSD Freelander diff for bike engine cars but it's pricey.
progers
posted on 21/7/06 at 02:14 PM Reply With Quote
The freelander diff is available in one ratio only 3.21 - this is ideal for the higher output bike engines (blackbird, busa ZX12 etc)
You can pick up new ones for around £2-300. They do not come with LSD. For that you have to upgrade with Quaife internals at a cost of around £1000.....
So the advantages are lightness and ratio (especially as sierra 3.14 is very rare)
Paul
andybod
posted on 21/7/06 at 07:28 PM Reply With Quote
beware of second hand ones as they do break and make some strange noises
posted on 21/7/06 at 08:44 PM Reply With Quote
for the record, they weigh 14kgs, which is 6ish kgs lighter than a normal sierra diff. They are much smaller too. The mounts are inconvinient as they are behind the driveshafts as opposed to in front like the sierra ones. The ratio might prove too low for my zx9 though.
