ruskino80
| posted on 22/7/06 at 06:15 PM |
r1 inj airbox sensor
running a pipercross filter what should i do with the airbox sensor??
G.Man
| posted on 22/7/06 at 06:54 PM |
put it in the filter area
it senses the air in the airbox, whatever airbox type you use...
[Edited on 22/7/06 by G.Man]
Opinions are like backsides..
ruskino80
| posted on 22/7/06 at 06:57 PM |
cheers a simple fix for a change!!
ChrisGamlin
| posted on 22/7/06 at 08:54 PM |
Yep, I just drilled a hole through the filter back plate and mounted it in there.
speed8
| posted on 22/7/06 at 09:04 PM |
How did you hold it in place. I was thinking of mastik or something like that (I don't have any nuts with that thread)
ChrisGamlin
| posted on 22/7/06 at 10:45 PM |
I think I found a suitably sized nut but Araldited it in place so if it ever came loose it couldnt find its way down one of the inlets, but I
can't honestly remember.
[Edited on 22/7/06 by ChrisGamlin]
ChrisGamlin
| posted on 22/7/06 at 10:49 PM |
Yep here you go
  ITG Backplate on 2003 R1 - 1
I might have even extracted the nut out of the airbox itself, I assume it was probably moulded into the plastic?
JoaoCaldeira
| posted on 22/7/06 at 11:05 PM |
IIRC it's the same threat / size of o Ford wheel nut (M12 x 1.5?)
Joao
speed8
| posted on 23/7/06 at 10:43 AM |
I've still got the airbox so I'll shred it and claim the nut.
gabbes
| posted on 12/8/06 at 06:20 AM |
I have also used a wheel nut from Ford and cut it in half - but remember to use a lockingwasher!!
