uklee70
| posted on 25/7/06 at 03:40 PM |
Airbox
Hi everyone
I was wondering if we have any airbox experts on hear
I feel the airbox on my triple is a little restrictive I have changed to a KN filter and now working how to get cold air to the inlets.
but at the end of the day would a larger fabricated airbox make any difference
I know manifacturers spend alot of money developing airboxes but have size restriction I don't so would I be better to fit a big square airbox
fed by cold air or faff around with current airbox and get a good cold air feed?
also are sock filters less restrictive than a KN filter
wow thats loads of questions sorry
Lee
rpsmith
| posted on 25/7/06 at 03:51 PM |
The only reason car manufacturers use air boxes is to reduce noise levels, replacing the air box with a K&N is the best way to de-restrict your
air flow.
What you should also do feed cold air to the new air filter as cooler air is more dense and allows for better combustion.
Hope this helps
Richard
[Edited on 25/7/06 by rpsmith]
RichieC
| posted on 25/7/06 at 04:14 PM |
air flow.
Sorry rpsmith, thats not true - Stand by for a volley of contradictions to that statement. Sound is only one reason an airbox is fitted. By fitting
an open filter you are admitting possibly more air but without doubt more turbulent air which is less desirable for an engine. Youve noted yourself
the tendancy to suck hot air unless something is done about that.
Given the choice an airbox is the way to go but unfortunately not all 7s allow fitment due to available size.
Bear in mind also, hes talking about a BEC - fundamentally though the theory is the same.
[Edited on 25/7/06 by RichieC]
Winston Todge
| posted on 25/7/06 at 04:40 PM |
This thread may help...
http://www.locostbuilders.co.uk/viewthread.php?tid=39230
